SOURCE: Pyrolytic cleaning won't start. Neff B15P42.0 GB
you have to remove the shelf supports (left and right) as well as the shelves. The manual tells you about the shelves but not the supports. I only found out as someone wrote the answer on another website
SOURCE: H4681 miele oven touchscreen is
do you have any error code there site says exactly this
Switch the appliance off. If the door lock will still not open this may indicate that there is a fault that needs to be investigated by an engineer. if you get an error code message me back the code here are what a couple mean
What does error code Fault 23 mean?
The temperature required for pyrolytic cleaning was not reached.
This could have been caused by too much soiling in the oven to start with.
Remove all coarse soiling before starting the pyrolytic cleaning programme again.
If the fault message continues to appear this may require further investigation by an engineer
What does error code Fault 33 mean?
This means that the door lock for the pyrolytic cleaning process will not open.
Interrupt the pyrolytic cleaning programme by switching the oven off.
If the door will still not open this would indicate that an engineer is required
What does error code Fault 32 mean?
The door has not locked for the pyrolytic cleaning process.
Switch the oven off and start the pyrolytic cleaning process again.
If the fault code continues to appear an engineer may be required for further investigation
please message me back with any further questions you might have and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
SOURCE: I get the error code FSE1, lock won't engage
F5 - E1
Self clean latch will not lock
1. If door latched:
2. If door not latched:
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
