The record will not eject. When I turn the unit on the record just spins. I can lift the arm and set the needle at the start of the record and you can hear the music at the needle but no sound out of the speakers. When it is done playing it just continues to spin the record, it won't eject it in order to play another.
There is a switch just under the tone arm. When the tone arm moves towards the centre it slowly pushes two copper strips together. When they meet it starts the motor to eject the record. If you can't Cancel the record with the cancel button then that is a different problem, otherwise you can adjust the trip switch by inserting a 7mm spanner down the hole to the right of the tone arm post.
SOURCE: No sound on 2710 Wurlitzer
Find the input to the amp from the tone arm. Play a record and while it is playing unplug the tone arm input. Stick a paperclip in the input of the amp...if it doesn't go HUMMMMMMMMM.....you have a dead amp....or the speakers arent plugged in.
Dave F.
SOURCE: Hi, I have a Wurlitzer 3600 Superstar that I am
Look at the switch and solenoid assembly at 1 oclock on the carousel. That is what activates to set it going and it then clocks off a ratchet wheel to do two full cycles looking for a selection then stops. If it gets stuck the carousel wont stop.
SOURCE: Wurlitzer 1015 OMT Disc spins, then stops....
Spoke with "Doctor Jukebox" from Folsom, CA about a similar problem I had. You can find him
on craigslist.
I did NOT have the "2222" display issue.
Root cause: The laser isn't "seeing" the CD and interprets inability to
see as being the end of the track, therefore, puts the CD back into the
carousel.
Solutions:
1) Clean the lens. Be careful to use an appropriate lens cleaning
solution. The lens is made of plastic and may cloud up if a harsh
solution is used. Use a Q-tip dipped into the cleaning solution and
gently clean the lens using a side-to-side motion, not a front-to-back
motion. Wait for a bit until the lens is completely dry, then try
playing a CD. (note: this fixed the problem for me)
If that doesn't work...
2) Replace the laser module. It's easy to remove with a torx. Be
gentle when disconnecting and reconnecting the ribbon cable and/or other
connections so you don't bend the leads. Laser modules cost a few
hundred dollars, so try Solution 1) above before replacing the module.
To remove a stuck CD from Tascam CC222
MKII
This solved the "Now OPC" problem
1. Unplug unit
2. Remove the top cover, (3 screws on each
side and 3 on the back, lift cover).
3. Plug in unit.
4. Power on the unit to observe the drive
spindle spinning clockwise, (1" disc on top of drive).
5. Turn off unit, do not unplug at this
time.
6. Use a small screwdriver to prevent the
drive spindle from spinning.
7. Power on the unit preventing the spin.
8. In approximately 10 seconds the display
will read "Disc Error" and the CD tray will open.
9. Remove the screwdriver and the disc.
10. Turn off the unit and unplug.
11. Replace the cover.
12. Use a better quality disc.
Also, I just noticed that the display shows record 905 playing, but 908 is actually playing. Also this is a 45 player not a 110 cd player.
