My mouse isnt moving and than something pops up and says that its frozen
On the top of your keyboard there should be F keys like F1,F2 etc.
Every F key has a little picture.When you see a touchpad picture press Fn+F5. According to my Laptop. For example if your touchpad picture is at F6 then you would press Fn+F6.The Fn key should be located near the ctrl keys. If this does not work then try the following steps:-
1 Click the Windows "Start" button in the bottom-left corner of your desktop. Scroll up and click "Control Panel."
2 Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner. Click the "Enter" button and then click the "Mouse" link.
3 Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have. If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button. If you are under the touch pad tab, click the enable button.
4 Click the "Apply" button and then click the "OK" button.
SOURCE: my keyboard and touch pad isnt working...
If your operating system is Xp / vista reimage your unit by hit F11 on started up & Hp splash screen - select advanced - select full destructive recovery - you have corrupted your device controler for human interface devices - like your k/board & mouse - there is no way to reinstall the required dll's so full recovery is required.
SOURCE: Mouse frozen on Laptop
try holding down Alt and press either F5 or F7
keep us informed please
regards
SOURCE: My mouse isnt working on our brand new laptop
During boot up get into the bios and make sure your mousepad is turned on.
SOURCE: the mouse on my laptop wont move
Boot up into safe mode and see if your mouse works. If it doesn't, then it is probably defective. If it works, then it would be a configuration issue in the normal side of the o/s. See if that will help you narrow it down. If the mouse pad is defective, it may not be worth fixing, just go out and buy a small usb laptop mouse. Good luck. -Carlos:
SOURCE: The mouse is frozen on
try to turn off the laptop, remove both battery and adapter, press and hold the power button for about 10 seconds, reconnect the power source and test the mouse/touchpad again. if same thing happens, test the system in safe mode and try to reinstall the touchpad driver.
