Screen Lights up briefly and we can see a picture for less than a second then it goes blank. Repeats the process when turned off and back on. Normal Sound is present.
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
SOURCE: Sony KDS-55A2020 picture goes blank then returns
This sounds like the ballast for the lamp is going. The ballast sparks the lamp, and if it starts to go, there's not enough current to keep the lamp sparked. Thus it starts to fail: it's the same principle as a fluorescent lamp fixture. Ballasts are available at any service depot, but they're fairly expensive, and perhaps prohibitively so; you may want to look at replacing the monitor itself.
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
SOURCE: Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the
timer/standby indicator blinks for about 30 seconds then goes to the
self-diagnosis function. Something is wrong with the video. Check video
out, Q705, 732, 761 and other components on the C board, also check
Q218, 219, 220 on the A board. In addition, unit could be in IK
blanking, try turning up screen slightly.
shaun
SOURCE: model hln617w. the picture on the screen freezes
Most likely your problem is on the DMD Assy Board P/N BP96-00249A . More presicely there is a few bad electronic components on that board that are bad. That board can be repaired by replacing the bad components (and the other few compoonents that are probly going bad and will soon cause your tv to lockup and lose remote and button functions when it fails so you will need to unplug it to get it on again).
Or the DMD board can be replaced .But it is not a cheap board.
For removal and Installation of the DMD board I would reccomend a tv service person because it is in the heart of the television and there are some adjustements to be made when the new board is installed.
To get the new board you could probably find it by just gooogling the part number.
Component level repair would require some experience in desoldering and soldering SMT,SMD , and or surface mount components.The actual components are about $15.00 total so just repairing your board should cost about $125.00 by a qualified servicer (if you were to remove and install it yourself). This DMD board is used in many models and can a few common problems.
HLM437W HLM4365W HLM5065W HLM507W HLM617W HLN437W HLN4365W HLN467W HLN507W HLN50665W HLN567W HLN617W ( L2 and L5 chassis )
SYMPTOMS:
-Intermittant picture freezing with a negative looking B/W frozen picture.
-Intermittant loss of pic with/without shutdown,abnormal color wheel noise if attempted to start after shutdown.
-lockup of tv control functions . Remote and front keypad do nothing , TV must be unplugged to reset .
-horizantal tearing, distortion , flippnig , solarization , red picture, leading to blank screen and lockup.(tv menu would be affected by all picture defects).
Hope this helps someone..
It is a plasma tv and I can get dvd to display - all connections are fine
