Samsung HTQ100 Shelf System Logo
Posted on Nov 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TUNER PROBLEM please advise me on what to do to my T-7J FM/AM/TV STEREO SYNTHESIZER TUNER (KENWOOD).i dont know how to make tuner work.there is a display but tuning, band, etc... seems like it is not working.it began when i use the sleep feature of its remote control.for not to worry on turning off the stereo, i used the sleep mode.but my problem, when i try to use its tuner again, i can not do so.i need your advise. tnx
  • 3 more comments
  • Kyaw Zaw 1620
    Kyaw Zaw 1620 Aug 17, 2017
    I also find like your problem at the same modle. Please let me know how to tune this T-7J KENWOOD tuner.
  • Kyaw Zaw 1620
    Myy e- mail address is ukz 1620 @gmail.com.
  • Mundia Wamulume Jun 05, 2019
    May someone help me with a step by step on how to program a Kenwood Fm/Am/Tv stereo synthesizer tuner T-7J.
  • Anonymous Dec 17, 2019
    This tuner work with a-7j amplifier with system control cable. Dont worry. Open tuner with screw driver. Inside has (test) jumper. Short it and relese. Now it will power on. But fm band end 90 Mhz. Enjoy. - wasanga ama..
  • Mc Jerald Blanco
    Mc Jerald Blanco Jan 13, 2020
    i already open the t-7j but i didnot find the jumper wher it is located?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 19, 2008
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
656
Points
You can try to reset, if not you can try to reprogram the entire system.
antoniorojas
Level 2:
Dedicated:
Visited the website for 20 consecutive days.
  • Expert 280 Answers
antoniorojas
Expert
Level 2:
Dedicated:
Answers
280
Questions
0
Helped
69417
Points
668
Probably you blocked dont worry unplugg it wait 2 mins and if your device has a reset switch just push it while you connect it. this most solve blocked devices....saludos
1helpful
How do I reset am and fm channels on a kenwood stereo synthesiser am/fm tuner kt-57?
Trisha, I beleive you use your autoscan feature, when it stops on a station you want to keep press and hold one of the preset buttons.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Keenwood KT 57 digital tuner
ORIGINAL OWNERS MANUAL FOR KENWOOD KT 57 TUNER0 results You may also like
2answers
Where can I find a manual for Kenwood Tuner kt-57?
Is it a tuner only? If so you will need a power and or just a receiver with speakers. A tuner only has no power output for things like tvs.
Need to set date and time on Kenwood stereo synthesizer tuner t-85l
Yo can find a manual at the link provided, it may help.
http://www.manualscenter.com/manuals/kenwood/t85l-service-manual.html#.V7sm_E1THIU
How do I set the FM radio stations on buttons 1 to 8
Try tuning to the station you want and then just keep the button pressed down on the preset you want to store it to until it saves
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Kenwood KT 57 Antenna Hookup
That unit uses a wire loop antenna and it connects to the rear under the screw terminals.
I have a kenwood stereo for 2000 saab 9-5. the tuner works but whenever i change it to cd you can no longer hear any music. it must be the wiring but i dont know which color wire is connected for the cd...
It sounds you are using an amplifier and using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on). Try hooking up the blue/white wire to turn your amp on. When leaving tuner mode, the blue wire shuts off, turning off the amplifier.
2answers
Need all new wires,were do i order them from
There is nothing unique to the signal or speaker wires used with this component. ANY hi-fi or electronics shop, online, eBay will have whatever you need. Your choice. Hint: standard 16-gauge lamp cord makes excellent speaker wire. Don't spend a lot on copper cables.
The manual:
http://www.retrevo.com/support/Kenwood-VR-405-Receivers-manual/id/480ag202/t/2/
1helpful
Kenwood Stereo
I presume you realize none of these things produces speaker amplification. A receiver would do that and facilitate graceful and simultaneous interconnections. But it's not a necessity for selective interconnective between them, just not all at the same time.
I can't find any details on anything you named except the Tuner.
Typically, the tuner would use an RCA pair to go to a receiver AUX, TUNER or other Line Level input for source selection and amplification. Lacking a receiver, run it to the Tape Deck inputs for recording.
Ditto for the CD changer, but you'll probably have to disconnect the tuner.
1helpful
3answers
Philips SAA7130 TV Tuner
Driver you have is not compatible! try to down load a newest version!!! and look on sound manager if mute is off
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
