Will not start. LED shows error code 125 and 126
SOURCE: Sta-rite heater error code 126
The 126 is not an error code, but it maybe the temp of the water that the heater is reading. If the heater thinks the water is 126 degrees, it will not start at all.
If the heater is reading the wrong water temp, the problem is the Thermister, which is the sensor that is suppose to read the water temp. You will need to replace this sensor in order to correct the problem with the heater. It is really easy to do!
If you have a manual for the heater, if you go to the Replacement Parts Listing for the Electrical System, page 53 in the online version, the Thermistor is Item #9. It goes into the left side of the manifold in the to place, between the first two manifold bolts.
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
SOURCE: sta-rite lp heater wont start
Its the top. There is a membrane that controls the circuit board....the button pad is bad
Testimonial: "Thanks, I agree. After checking power supply all the way through to control board, placing a jumper from pins 9/8 and 9/7 on J6 I get lights on LED's"
SOURCE: sta-rite pool heater won't fire...
nomoneytom did you find solution if so let me know I have same issues. Thanks
SOURCE: what does R8 code mean on sta rite pool heater
These pool heaters have a very detailed and specific troubleshooting manual that will probably be the most helpful thing for you. They ask very specific questions about what appears on your heater and you will need to be looking at it to troubleshoot. Try walking through the troubleshooting guide below.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
