Vacuums Logo
Ken May Posted on Apr 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The motor on my riccar 8650 is very loud. is there brushes that can be replaced?
Thatvacguy.com
Level 3:
  • Riccar Master 1,619 Answers
  • Posted on Mar 08, 2014
Thatvacguy.com
Riccar Master
Level 3:
Answers
1619
Questions
0
Helped
604396
Points
3345
Your. 8650 is likely well over 20 years old. It has carbon brushes in the motor that may need replaced but your best bet Is to take it to your Riccar dealer to diagnose it or you might replace the wrong thing. You have a very durable long lasting machine obviously but there are minor things that need occasional service to keep it running properly for many more years. This series started with the 8600 models of which I still have many brought in for annual service. There has been an 8700 and 8800 series and now the latest 8900 series which has been out well over 10 years.
3 Related Answers
Anonymous
  • 701 Answers
  • Posted on Dec 15, 2009
SOURCE: Riccar 8800 belt replaced but now floor brush won't spin
Are you sure that you get the right sized belt? This is the correct one you need:
Riccar 8800 Belt
Anonymous
  • 438 Answers
  • Posted on Mar 21, 2010
SOURCE: Changing Belt on Riccar 8650
Greetings from GoVacuum,
I will attempt to walk you through the belt change on your Riccar 8955 upright vacuum cleaner. I have taken pictures for you for each step to ensure that it's done properly. What you'll need to have handy for this repair;
- Phillips Head Screw Driver
- Riccar 4000 / 8000 Series Belt
- Riccar 8000 Series Roller Brush With Clutch Assembly (only if the brushes have worn down, not necessary if brushes are still long)
Step 1: Make sure the vacuum cleaner is unplugged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 2: Unscrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush
Step 3: Remove the belt guard that sits to the left of the roller brush, and is a metal part that protects any dirt & debris from going over to the belt. Here's a picture of that part being removed;
Step 4: Remove the Rug / Floor actuator arm from the clutch on the right hand side of the roller brush. Simply pull the metal actuator arm to the left of the brush and out of the circle that it sits in. Here's a picture of that;
Step 5: Once you have removed the actuator arm for the clutch, as well as the belt guard, lift straight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 6: Once you have removed the roller brush, and the old belt from the vacuum cleaner, take one new belt and wrap it around the metal pin in the back of vacuum cleaners agitator housing. Here's a picture of where that pin is located with the belt wrapped around it;
Step 7: Once you have the belt wrapped around the metal pin (this is the shaft to the motor that actually spins the belt), but the other end of the belt through your new roller brush;
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, and continuously having to replace belts. You can see on the end cap of the roller brush (the right side where the belt rides) that there is two little teeth that protrude out of the end cap as well as an indentation on the opposite side;
Step 9: With the roller brush inserted through the belt, position the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove down inside of the housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
Step 10: Replace the metal belt guard that rests to the left of the belt. You'll notice on the belt guard that there are two little 90 degree notches on both sides. These notches need to face towards the belt or to the right. Here's a picture of the belt guard being put back into place;
Step 11: After inserting the belt guard back into the vacuum, turn the vacuum cleaner over so the top of the agitator housing is facing you. Change the the rug / floor switch from bare floors to the carpet setting, and the turn the vacuum upside again so the brush and belt are exposed:
Step 12: With the vacuum set to the carpet setting, pull the belt forwards to ensure that the brush is spinning freely. If the belts do not spin freely, repeat steps 2-10.
Step 12: There is a flap that can be opened after the metal bottom plate has been removed, that will give you more access to the motor shaft. Make sure that this flap is closed;
Step 13: The last tricky part can be reinstalling the metal bottom plate. There is a little lip on the front of the vacuum cleaner that the edge of the bottom plate has to slide under for it to be installed properly. A lot of people just install the bottom plate over top of this lip, and this prevents the brushes from hitting the carpet as low as if the bottom plate is correctly installed. Here's a picture of the lip with the bottom plate in the backgroud;
Step 14: Slide the metal bottom plate into the lip on the vacuum cleaner, and fasten the screws back into the bottom plate to secure it. The lip is a little tricky, but after doing it just once, you'll have no problems in the future changing your belt.
Here's a picture of the bottom plate installed INCORRECTLY with the bottom plate over top of the lip;
Here's a picture of the CORRECT way to install the bottom plate:
I hope that this repair solution is helpful to you in installing the belt properly. If you found this helpful, please be sure to click the 4 Thumbs Up Icons in the top right hand corner of the solution. Feel free to request a clarification of the repair if you have any questions about this repair, or other repairs. I'm always happy to answer any questions.
Thank you very much,
Chris J.
Anonymous
  • 2047 Answers
  • Posted on Sep 08, 2011
SOURCE: Problem with Riccar 8850 Vacuum There
Hello there, when sparks come flying out of your vacuum cleaner it usually is as a result of messed up connections and power fluctuations.The probability of the motor needing replacement is very high as unless i examine it i cannot say for certain but one thing i can say for certain is that the entire wiring of the unit has to be inspected thoroughly because this is where the main problem would have emanated from. The unit would definitely need other components other than the motor changed this is because if the other components which have been affected dont get replaced then even a new motor will face the same problem after a relatively short period. best refer the unit to an expert to determine the extent to which the other components are affected and what other parts are damaged. Also to determine if the entire motor needs replacement or some part of the motor can still be salvaged.
Hope this support has been helpful?
Thank you for visiting FixYa.
I have a Riccar Brilliance. When I turn the vacuum on, the bag pushes so hard from the inside it starts to push through the left side...
I can’t really help with the bag issue because I’ve never heard of that before. But my guess is that the bag isn’t breathing properly or is overly full. If the vacuum sounds louder it’s possibly because the fan is off balance and/or the brush could be bad. To test this turn both switches on and listen is the vacuum sounds normal then we know it’s not the bypass motor. If however you put the handle back and the vacuum is loud it’s probably the fan in the direct air motor. You can also take the brush out and do the same test to see if the loud noise is coming from the brush. If you take the brush out and run both motors and they sound fine, you know the problem is in the brush. Hopefully that helps.
1helpful
Riccar 8650 vacuums reset.....cannot find as stated just above left wheel and to the right....all smooth dark blue plastic housing
Your 8650 is likely about 30 years old. It may not have a reset switch. If it won't run it may need a new cord or switch. If it's in good shape it may be worth having it looked at by your local Riccar dealer.
Looking for a parts list / manual to replace the motor
You will need to purchase the motor from a Riccar dealer. If you don't have a local dealer contact me at [email protected]
1helpful
Why does my riccar supralite vacuum makes a loud rattling noise like the roller is banging around?
You have something wrong with your brush roll or you have damaged the fan. Remove the brush roll and belt and turn the vacuum back on, if the noise is gone it is likely something wrong with your brush roll, if the noise persists you probably have a broken fan. You have to remove the motor and fan housing after removing the top cover, unscrew the bolt holding the fan on and install a new fan (you can get one from any Riccar or Simplicity vacuum dealer)
Riccar 8625 doesn't seem to beat carpet but the brush is turning
Your 8625 is well over 20 years old. If it's been over a year since you've replaced the belt start with a new belt. Belts lose elasticity and should be replaced at least once or twice per year. The brush roll will still spin and appear to be working fine but when you put the brush roll onto the carpet it will stop spinning fast enough to clean the carpets.
How to install belt on Riccar 8750 commerical vacume cleaner?
No. There is only one belt. Remove the bottom plate to gain access to the belt.
Troubleshooting
There is a clutch on one side of the carpet head of the vac, which needs to be moved to one direction or the other. Your instruction manual should be able to tell you which way is which. This lever in turn activates a cam to tighten a clutch plate to the end of the brush roll. Try that and get back to me.
How do I replace the belt on my ricaar model 8750 vacuum?
Remove the bottom plate to access the brush roll. Remove the brush roll to install a new belt. Your
model is over 20 years old. If it has never been Professionally serviced it may be wise to take it to a Riccar dealer for service. It could add many more years of life to your vacuum.
Light comes on but not the motor
There is a small tiny button on the back near the bottom. Push it that should start the motor. There is a reason it shuts off, usually clogged somewhere
5helpful
3answers
Chris J.
Top Riccar Vacuums Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
