Manual
SOURCE: manual for an OscarJuice Extractor ?
Here the manual for Oscar 900 that is quite similar, the operations and recipes should be the same.
SOURCE: Juice extractor - dismantling after use
Look at the dismantling and cleaning procedure in JE95XL Juice Fountain Plus user manual on Page 14 and 15. Procedure is the same with JE900.
http://www.breville.ca/site/EN/products/je95xl/je95xl_manual.pdf
This is what manual doesn't tell you: clean the 3 spring loaded pins on the side of the motor clutch. Sugar and pulp may get inside and seize them when dries up, thus making very hard to separate the basket/cutter from the clutch.
SOURCE: OPENING the JC-250 Juice Extractor
Hey, you probably have figured it out! I just got a juicer without a manual and couldn't find a way to dismantle for cleaning but I got it!!!!!!!!! Just put it upside down and twist and turn. Everything will fall off ( cutter and container). I'm so happy to help!!
SOURCE: I need manual to learn how to use it
If you Google your query you will be able to find the manufacturer, they should be able to help you with a manual for this model. I hope this is of some help.
SOURCE: Looking for downloadable juice extractor book
BOOK CALLED "JUICING FOR LIFE" AT AMAZON.
TRY 2 CARROTS, 1 APPLE, 2 CELERY STALKS
AND A HALF LEMON. ALSO IF JUICER BREAKS,
GO FOR SOMETHING BETTER LIKE AN ACME.
HAVE ONE SINCE 1990.
