I assume you bought a PS2 game that works on your PS2 system but not on your PS3 system since a PS3 game will never work on a PS2.
Since not all PS3 systems can play PS2 games, you need to first check the model number of your PS3 system. If you look at the back of your PS3, there should be a serial number somewhere that starts with "CECH", followed by one more letter and a couple numbers (e.g. "CECHC02"). Unless the model number starts with "CECHA", "CECHB", "CECHC", or "CECHE", you won't be able to play PS2 games on your PS3.
If your PS3 can play PS2 games, then you need to make sure that the region of the PS2 game matches the region of your PS3. The region of the PS2 game can be found in the upper-right corner of the front of the box the game came in. The four regions are: "NTSC U/C", "NTSC J", "NTSC C", and "PAL".
Once you know the model number of the PS3 and the region of the PS2 game, you can tell if the PS2 game should work on the PS3. Use the following chart to determine if your game and system are compatible:
Last two digits of your PS3 model number: Playable PS2 game region
00: NTSC J
01: NTSC U/C
02: PAL
03: PAL
04: PAL
05: NTSC J
06: NTSC J
07: NTSC J
08: PAL
09: NTSC C
11: NTSC U/C
12: NTSC J
SOURCE: American PS3 in South Africa
Hey thomas952,
While they may not be region-coded, PS3 consoles and games sold within the United States are going to be NSTC compliant, instead of the PAL format used in the United Kingdom and South Africa. What this means is that in order for any game to display properly (or even operate) it must be purchased from the same region of the world as the console itself - NTSC games can only be played on NTSC consoles.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
I brought a alarm clock for my daughter and all the instructions are all in chinese
