Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite quiet pak 4 ''suds'' error
I have a kenmore elite quiet pak 4 front load washer (not sure if it is the the 45986 listed below) and it has stopped and currently shows the word "suds".  What should I do to complete the cycle? Also, can you tell me if it is safe to use a concentrated (x2) detergent.  Thank you in advance.
  • Anonymous Mar 29, 2014
    Open front panel
I also gots suds error and then "F"?
my clothes were soaked....i can't get the machine to drain now????
Posted on Jan 09, 2009
    Genius:
  • 1,028 Answers
If it is truly oversudsing cut back on detergent or go back to standard he detergents not totally convinced of concentrated detergents are best way to go..if not oversudsing remove bottom cover and clean out pump pump restrictions will sometimes generated suds code
Posted on Nov 18, 2008
  • jerry
    jerry Mar 17, 2014
    How do you clean out the pump
6ya staff
SOURCE:
Kenmore elite smartwash quiet pak 4
This video will show you how to change a door seal on this Bosch front loader washing machine
You can find more Bosch videos in our Bosch repair channel
Jul 22, 2013 | Kenmore Elite 45986 Front Load Washer
Kenmore elite 5t steam f35 and sud problem
The F35 error code indicates a problem with the analog pressure sensor, air hose or air trap. If the hose and trap are good you will need to replace the pressure sensor
The "Sud" error code indicates too much or the wrong kind of laundry soap was used. Be sure to use only HE (high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Sep 25, 2011 | Kenmore Elite 45986 Front Load Washer
I have quiet pak 2 kenmore elite. It will not start and displays f dl
i have the same problem right now today hope some one knows how to fix it ,, have cleaned out bottom hoses and catch pan nothing ..
Feb 17, 2010 | Kenmore Elite 45986 Front Load Washer
Door won't open
the lock switch is probably stuck. make sure machine is off but plugged in still. Push in on the door while gently giving a couple of thumps around the lock area and the lock will probably "click" open.
Aug 16, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elete 45862401 Quiet Pac2 front end washer that stops during the wash cycle. it flashes a f6 error code. The manual says it is a loose wire between the mcu and/or control panel,shipping...
With the front door open, see if you can rotate the basket freely.  If not, most likely the bearing of the rear tub is worn out.  You will have to replace the whole rear tub which is about $300 for the part.  I am having the same issue with my Kenmore Elite Quiet Pak 2.  I'm contemplating with just buy a new top-load washer.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite quiet pak 4
its a inlet water supply error code check your cold fill line and fill screens at cold fill valve for block
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE SMART WASH QUIET PAK 4 FRONT LOADER,
Now this is a drain issue from the pump, clean out or check drain hose position to make sure hose isnt in water. Front loader right? kick panel under door has two screws, 1/4 or Torx T20 will remove them. You will see a clean out screw handle that holds junk. Use a trash bag wrapped around the clean out to catch water and debris..
Kenmore Elite 45986 Front Load Washer Logo
1,934 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
