Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
Posted on Aug 24, 2017
Water leaking from top of RO system.
I have a Kenmore Universal RO home drinking water system, Model No. 625.347030. Water is leaking from the top of the RO cap. I have replaced the top threaded cap, o-ring, diaphragms, and the plunger. Can you recommend how I proceed to stop the leak? The system is 10 years old.
Don Gerkin
480-312-7903
5 Related Answers
Anonymous
  • 126 Answers
  • Posted on Dec 14, 2007
SOURCE: kenmore refrigerator leaking at water filter
make sure old gasket came of with old filter or make sure it is real tight you should have got a wrench with the refrig.
Anonymous
  • 531 Answers
  • Posted on Apr 02, 2009
SOURCE: Taste of water from water dispenser has "plastic taste"
you have to flush dispense water on till taste gone
Anonymous
  • 8619 Answers
  • Posted on Apr 17, 2009
SOURCE: water leaking inside the refrigerator
Hi
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
gdcroft
  • 192 Answers
  • Posted on May 31, 2009
SOURCE: water is leaking on the
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle. I'd also recommend checking to make sure the ice maker is not leaking.
Anonymous
  • Posted on Dec 19, 2010
SOURCE: kenmore coldspot model 106: top freezer leaks
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
My 2004 Kenmore leaks water at the water filter housing. I put a new filter in but when I wish to get water it overflows at thde top.
Fist issue, plumbers putty should not be used on any water connection for potable (drinking) water, use Teflon tale if you need to. If the leak is at the housing most likely the housing is bad, replace it.
Water leaking inside my vegetable drawer
Just above the drawers is a drain hole on the back wall. Push a drinking straw or very thin brush down to unblock the drainhole and the water will drain away outside the rear into a pan on top of the compressor
4answers
How does a water purifier work?
A water purifier works through the process of reverse osmosis. Water purifiers cleanse water by passing it through a series of filters. This helps remove large amounts of contaminants and other harmful chemicals
Leaks on the top of black box of culligan water softner under sink system
Is this a reverse osmosis drinking water system? If it is it is an H8 RO. If so shut the water off that feeds the RO. The leak is probably coming from one of the fittings, they can be cut by the compression fittings and leak.
RJ
1helpful
My undersink RO system leaks at all four tube connections on the manifold. I inspected the fittings and the o rings are fine. I inspected the tubes and I cut off the ends of each piece to make sure that...
The quick connect fittings need to be fully seated or when pressure is applied they will leak. If the feed is pressure is high to the RO I have seen this occur also. JG John Guest makes a small locking clip that goes on these fittings to hold them tight. Here is a link to JG which shows this application.
http://www.johnguest.com/Home/applications/beverages-and-drinks-dispense/Inch-Size-Accessories/LOCKING-CLIP.aspx
RJ
1helpful
Leak at one of the fittings on my Culligan RO system
Too much pressure in holding tank will not cause leaks in the RO unit. All too much pressure in tank will do is cause low or no product water in RO tank. Older Culligan RO systems (H8, H83, H5) had fittings that used metal locking washers and these can cut the RO line after the RO has been moved around while changing filters. Newer styles (AC30, Water Tower) use quick connect fittings and the RO line may work loose after filter changes and system being moved around under sink.
Turn the incoming water off to RO, turn the water off on RO tank, open the RO faucet to relieve pressure and pull the line off feeding the RO tank, inspect (you may want to cut off a small portion of the line at the filter) check the o-ring and re-install.
RJ
I have a GE PROFILE R/O System with a chrome dispenser; I need a brushed nickel dispense; where can I get one???
An RO drinking water air gap faucet would be the ideal faucet to purchase for your RO system. Here are a few options you can choose from that may come in brushed nickel: http://www.freshwatersystems.com/c-821-ro-drinking-water-air-gap-faucets.aspx
Which is the best RO system to use for an LG side-by-side fridge?
You realize you asked a simple question for a very complex answer. Water supply is the first key and that water supply depends if the reverse osmosis has been applied there before reaching your refrigerator. I can name many countries where the water you see you cannot drink but only purchase purified water. If you have clean and safe drinking water in your home then use the recommended filter that LG reccomends. If not then I recommend Omni Pure. Thanks, Sea Breeze
http://www.omnipure.com/
15answers
is there an internal float that is stuck allowing overflow?
Nov 18, 2008 • Plumbing
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
