My psp is slim and it is 6 months old can anyone help
SOURCE: PSP SCREEN FLICKERS AND GOES SLOW IN MAIN MENU
Ok...this sounds crazy but it happened to one of my PSPs. I updated the firmware on my system and the menu started stalling and taking a long time to respond. I shut the PSP all the way down....holding the power button until the light shuts off (about 4 or 5 seconds)...Hold the R button and power the system on again (you should be in recovery mode)...go to CPU speed and make sure it is either set at "Default" or "222"....I belive 222 is the default setting....also make sure the UMD is also set at "Default" or 222....if you're going to use the UMD.
SOURCE: Can't find AOSS Button in psp
you are doing it in the wrong menu. you are setting up a connection to location free player
you need a wireless connection. And so after that, you go to the internet icon,and then you just type in your link.
1. Go to the Main Menu of your PSP.
2. Go to Settings.
3. Scroll down to Network Settings and Press the X button.
4. Select Infrastructure Mode.
5. Select New Connection.
6. Name the connection so that you know it is for web browsing. (ex. WebConnect)
That way you can use another connection for the rest of your online games.
7. Push the Right Direction Key to go to the next menu.
8. Select the Scan option and let it pick up your WLAN settings.
9. Once it picks up a connect, Push the Right Direction Key to go to the next menu.
10. Select Custom for the Address Settings.
11. Push the Right Direction Key to go to the next menu.
12. Leave IP Address Setting on Automatic.
13. Push the Right Direction Key to go to the next menu.
14. Select Manual for your DNS Setting.
15. Push the Right Direction Key to go to the next menu.
16. Enter in 67.171.70.72 as your Primary DNS and just leave the Secondary DNS blank.
17. Push the Right Direction Key to go to the next menu.
18. Select "Do Not Use" for your Proxy Server settings.
19. Push the Right Direction Key to go to the next menu.
20. Push the Right Direction Key to go to the next menu.
21. Push the X button to save your settings.
22. Do a quick test of the connection to make sure it's working correctly.
first
you need to have a wireless internet at home. next you need to turn on
the wlan on your psp, located at the left side corner of your psp.
search for a wlan around you. if its not secured, your lucky, you can
connect anytime, but if it has a wep key, you need to find out the key
to be able to connect.
Switch the
wlan button (located on the left side) to on and if don't aoss router
seperate from the psp you cannot use automatic. So goto new connection
and press scan. Follow on screen instructions.
If you do have an aoss router press button on the aoss router inself so the psp can find it.
Okay now that ive given you your answer make sure to follow fixya's system. Instead of taking the answer and running.
THANK YOU,
NATE
SOURCE: Directional buttons for PSP not working.
Star wars: force unleashed was a bad game... anyways:
Maybe the disk isnt read rite by your psp. maybe the disk is wrong?
Or it could just be that you dont use the directional buttons for gameplay, just the analog stick. XD
