I unplugged it for a "HARD RESTART" NG. The "Start" button and "Cancel" button do not work, but the unit works properly when the "Add Minute" button is pressed. Is there a CONTROL PANEL replacement available for this unit?
SOURCE: Maytag Microwave MMV5207AAQ control problem.
Nuke, Sounds like your touch pad is going south. Why dont you kill the power, drop the control assy. and unplug the ribbon of the control panel to the board. Take an eraser and clean the ends of the ribbon where it connects to the board. Put it back in and see if that made a difference. If not I would suspect it's the touch panel. The part number I have for this is 53001508. Good luck.
SOURCE: Matag Microwave MMV5100AAB
There is a short either in the keypad or the power board. Unfortunately parts for this one are not available anymore. If you could get the parts it would cost you well over $100 and would be a better idea to replace the microwave. If this only happens when you add time then I would just use the microwave without using that option. Would appreciate a solved rating for expert advice.
SOURCE: MMV5000BDW Touch panel works intermittently
You have a failing keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: i need to replace my maytag mmv5000 microwave door assembly
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
SOURCE: MMV5000ADW Maytag Microwave Keypad stops working.
How old is this unit? have you taken it apart?there was at one time a wiring issue with these units,depends on the age.other wise I'd say you have a bad touchpad it was another common issue with this unit. part number 56001263 in white runs around $80
Testimonial: "Great answer"
