Question about Jura Capresso Impressa E75 Espresso & Coffee Maker
Malfunction light on Jura E75
After I turn on unit it flashes "please wait' for a couple of minutes then switces to "malfunction 5" or possibly it says "malfunction E".
Prior to the problem I had cleaned the water tray. I also pressed the rinse buttom a couple of times then used the frother. The frother seemed to overheat and steam emerged from the top of the unit. I then shut the unit off to cool. After that couldn't restart without the problem noted above.
  • Anonymous Mar 18, 2014
    My Jura keeps saying please wait and does not go to the second step of 'rinse unit'
I just called the company with the same problem today. They will fix your machine for free. They have recalled this machine. Call them and they will tell you what to do. 201-767-3999
Posted on Mar 20, 2009
6ya staff
SOURCE:
Lock light is flashing when I push bake it says door
Hello meathead4094 - Often when the LOCK light is flashing, it is because there is door malfunction. Try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Typically, this will clear the flashing. If issue persists, the range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I would strongly recommend contacting a professional to get the appropriate diagnosis prior to make any unnecessary part replacements.
Apr 18, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Display tap on Jura Impressa E75 say close tap, where is tap please
The tap is the dial on the left turn it, then it will turn the tap off. If it is repeating this then it may need to be decalcified.
Sep 06, 2012 | Jura Capresso Impressa E75 Espresso &...
How to fix error message 8
DISPLAY SHOWS MALFUNCTION 8 Solution: Turn off and unplug machine. Wait a minute. Turn machine on and wait until it stops making any noise. Now try to pull out the drawer. If this does not work, try the procedure again. If this does not work, call customer service
Regards Kat (please leave feedback, many thanks)
Aug 19, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
PO1693 CODE WHAT'S MEANS
that code is for a MIL indicator malfunction-in other words, your check engine light is malfunctioning...do you have a MIL light that works when you turn you key on, before starting? If not, the bulb is blown out, and you should replace it. If it does work, I'd suggest disconnecting the negative battery cable and letting the car sit for 5 minutes, then start it up and let it idle (no gas at all) for 5 minutes, then drive it lightly for another 5-if the light stays on, you have a malfunction with either the wiring to the light or possibly the ECM.
Mar 03, 2011 | Kia Sportage Cars & Trucks
PT61LCZ70K panasonic tv won't turn on, flashes green light for a couple of minutes then flashes red twice then stops and flashes red twice again. TV Made in Feb 08 lamp shouldn't be gone yet. Manual says...
have a tech clean inside cabinet and replace bulb , should be under warrantee if under 5 years old just had mine done free of charge from panasonic call 1 888 843 9788 they will direct you to a dealer. hope this helps
Oct 01, 2010 | Panasonic PT-61LCZ70 Television
Impressa S70 - Malfunction 3
This indicates that either the sensor for the thermoblock is defective or the thermofuse is blown. For this you need to go to your local dealer for service. I also recommend that you measure out the mains.
In worst case the powerprint or the mainboard sends wrong signals to the thermoblock so it`s overheated.
Aug 02, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura impressa E75.message mafunction 8 shows up
Malfunction 8 is related to the brew unit typically. It is usually an indication of the brew unit motor having to work too hard to move the brew unit up and down. This is usually cured by disassembling, cleaning, replacing any o'rings that may be bad, and lubricating the unit, then reassembly.
I have had to do this twice on an an E75 and an E8. I finally broke down and bought seal kits and lubricant for doing this. One could by a new brew unit off of e-bay and change out the whole thing. But a simple rebuild will typically suffice.
Mike
Aug 12, 2008 | Jura Capresso Impressa E75 Espresso &...
Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
May 12, 2007 | Jura Capresso Impressa E75 Espresso &...
Jura Capresso Impressa E75 Espresso & Coffee Maker Logo
375 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
