Question about Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer ()
Craftsman 27cc weed wacker will not turn shaft when running
Weed wacker starts fine, just will not turn shaft to engage head
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Replace head gear box.
Posted on Oct 18, 2013
6ya staff
SOURCE:
Mike Squire
  • 420 Answers
SOURCE: i have a string craftsman weed wacker an the
Turn the big knob on the bottom LEFT to loosen it in order to access the drum with the line on it.
Posted on Jun 04, 2010
canalesfam11
SOURCE: 358.791070 filters for Craftsman weed wacker
Where is the fuel filter?
Posted on May 18, 2011
rajoy1
SOURCE: trying to install a hassle free trimmer head on a
I had the same problem today. Store told me part 71 85740991 would work.
It does not have same shaft to attach. The original has a plastic head which
melts with use and will not work. I feel it is a defective device. They have a replacement part that does work for a while and does the same thing. Sears
should provide a proper head. A higher priced machine has a proper head.
I would like to by the better shaft and head which I think would fit this machine
but am told you can'[t buy. I'm very discouraged with them. Then engine runs fine.
If you find a solution I would like to hear from you. Thank you.
Posted on Jun 06, 2011
David Petry
  • 961 Answers
SOURCE: weed wacker model 21032 engine
I am not finding your trimmer right off the bat but, these units have a drive cable in them joined with plastic couplings. More than likely you have a rounded out coupling and/or a broken cable. You have to make sure, however, that the shafts are joined together all the way to make sure the cable can engage the coupling, Loosen the knob on the shaft and separate the two pieces, see if the cable spins when you run the trimmer. If it spins without lower end on, try putting back togrther and see what happens. If the cable was spinning when apart, the problem is in the lower half.
Posted on Jun 12, 2011
chip
  • 16 Answers
SOURCE: weed wacker started and wacked some weeds then the
pull off string housing check that all parts are there. run machine and see if shaft is turning-- if it is then put housing back on sometimes I havent put the housing on properly. if shaft is not turning. then repair is needed. or just buy a new one. cost of repairs on this stuff is not worth the cost. unless it's a profesional grade machine..
Posted on Dec 07, 2011
Replace head on toro model #51954 curved shaft trimmers
https://video.search.yahoo.com/yhs/search;_ylt=AwrTcdIyalFXg.QAUmAnnIlQ;_ylu=X3oDMTByNWU4cGh1BGNvbG8DZ3ExBHBvcwMxBHZ0aWQDBHNlYwNzYw--?p=Toro+Model+51954+Weed+Trimmer+Owner+Manual&fr=ytff1-msgr&hspart=mozilla&hsimp=yhs-006
Jun 01, 2016 | Toro Garden
Barely used weed wacker head stopped turning clutch seams loose has play can i unscrew the clutch?allen wrench??
If your clutch is spinning you more than likely have broken the drive shaft that goes down to the head. it is fairly common with craftsman weed trimmers.
Nov 06, 2015 | Garden
I need to replace the head on this 32cc weed wacker and the bolt shaft keeps spinning keeping me from putting on the new head. Am I missing something?
There is normally a large alloy nut that goes on first, it sits ont the two short flats on the output shaft so as to be able to hold the shaft to fit/ or remove the trimmer head.
Jul 30, 2011 | Garden
My troy bilt weed wacker started to make a rattling noise from the engine a couple of weeks ago. Now the head has stopped turning, it appears that the drive shaft is not turning.
sounds like something came look in the clutch assembly. you have to remove the shaft from the power head and take a look inside the cover.
May 30, 2011 | Troy-Bilt Garden
Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Apr 13, 2010 | Craftsman 25cc Gas Line Trimmer
McCulloch mt 700 weed wacker,the weed wacker will not spin to cut the weeds
If the motor is running another possible solution is you have a broken drive shaft spring PN-753-04280 To check this remove the screw which holds the **** pipe to the motor and loosen the clamp. The **** pipe should pull right off the motor exposing the end of the drive shaft spring. Pull the end of the spring, if it comes out it is broken.
Jul 06, 2009 | Garden
Craftsman gas weedeater. Engine runs, but the head won't run
Cut 1/8" off outer (aluminum) shaft. Lube inner shaft with STP or heavy gear lube this will re-engage worn square drive .Replacing inner cable is un-necessary this is normal wear. Sears Master Tech BB
May 26, 2009 | Craftsman 25cc Gas Line Trimmer
why does my weed wacker burn white smoke
Nov 17, 2007 | Washing Machines
Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer () Logo
716 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
