Dell Dimension 2400 PC Desktop Logo
Anonymous Posted on Sep 15, 2017
UPDATE FOR DRIVER VER.6.14.10.4544? DELL 2400 WHEN I PLAY VLC, OR ANY OTHER VIDEO THE SCREEN SHOWS MANY FLASHING RECTANGLES
MONITOR IS A GATEWAY EV910 IN GOOD WORKING ORDER. AS STATED, WHEN I PLAY A VIDEO FROM ANY SOURCE,MEDIA PAYER,VLC,MPC HOME CINEMA.THE SCREEN SHOWS APPROX 5000 RECTANGLES ALL FLASHING, THEN I CAN'T OPERATE MOUSE, CONTROL,ALT DELETE NOTHING, I HAVE TO UNPLUG IT,AND REBOOT IS THERE A UPDATE FOR THIS GRAPHICS CARD. THANK YOU
Minister Ruland
Level 2:
Sergeant:
  • Dell Expert 445 Answers
  • Posted on Sep 17, 2018
Minister Ruland
Dell Expert
Level 2:
Sergeant:
Answers
445
Questions
0
Helped
127360
Points
810
The mail problem with those dells is the video card was not very good. you can go to dell and put in the tag number and download the drivers for it and that might help. the old dell was a xp machine and it might be the only drivers you can get for that. if you have upgraded to windows 7 there are not drivers for that in w7
5 Related Answers
Open SKy
Carlos L. Burgos
  • 620 Answers
  • Posted on Dec 21, 2007
SOURCE: Video card
Hi, Yosemic
Happy Holidays,
Sometimes is difficult to accept the reality of technology, but is happend, there is no 512 RAM video for this particular PC, but you can found for 256 ram, yet from Nvidia or Radeon taste.
PCI-E is eating the market.
(time to change your MOBO)
Anonymous
  • 156 Answers
  • Posted on Jul 26, 2008
SOURCE: Added a memory stick to my Dell 2400 Desktop computer and the monitor, mouse, & keyboard won't work
Hi
The supported Memory types for Dimension 2400 Series is PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC). Supported Memory capacities are 128, 256, or 512MB and a Max if 1GB (1024MB).
The first obvious question is does the new 512MB Memory module meet the above specification? Some Memory modules are able to steep down speed.
If it does, then first ensure the new memory module is properly installed. Take ESD (ElectroStatic Discharge) precautions or you may damage the new memory module and/or the system board.
To proceed compare the system beeps and diagnostics lights color and sequence to the Advanced Troubleshooting guide.
It is possible that the new memory is DOA (Dead On Arrival). Or there is a new fault on the system. If you have access to another compatible system, you may test the new and old memory modules. You may also swap the new and old memory modules to determine if the memory slot is at fault.
Lastly, if you remove the new memory module, does the system complete POST (Power On Self Test)?. If it does you may indeed have a DOA or incompatible part.
Mike
Anonymous
  • Posted on Oct 15, 2008
SOURCE: Computer freezes up. Only unplug power cord can I reboot the computer.
  1. Dell suggests upgrading audio drivers and flashing bios.
  2. I did both of these and problem reappeared after a while.
  3. Then I removed heatsink/fan assembly,cleaned all surfaces,applied good quality silver-loaded heatsink compound and reassembled
  4. PC has been running for more than a day with no probs so far
Anonymous
  • 11 Answers
  • Posted on Feb 12, 2009
SOURCE: Dell C521 Where to connect monitor?
This means that you have an external video card (which is not outside the computer). This video card will be plugged into the motherboard. That message is saying that the port on the back of the computer that your monitor is plugged into is the wrong one. You need to look for another port on the back of the computer.
Here is a picture of a VGA port that you should use if you have a VGA cable to connect the monitor (Blue Ends).
http://news.softpedia.com/images/reviews/large/VGA.jpg
Here is a picture of a DVI port that you should use if you have a DVI cable to connect the monitor (White Ends).
http://zedomax.com/blog/wp-content/uploads/2008/09/dvi.jpg
So depending on the cable and connections that are available on your computer and your monitor depends on what you have to use. I hope that wasn't too confusing. Let me know if you need more info.
ahsan322
Ahsan Ali
  • 38 Answers
  • Posted on Aug 26, 2009
SOURCE: dell dimension 2400 will not boot. Diag lights A & B amber.
first of all dnt take tention,
firstly remove ur all RAMs then reboot ur system. after that flash the motherboard cell.
after that reboot ur system, if yous system have same problem then plug out all hadware of ur system except VGA, RAM, Hard Drive,and key board. after this u may restart ur PC and then check it out.
hope so ur problem is solved
1helpful
New laptop wont show video
If the laptop has Windows 10 and you are trying to view videos with the default Windows media viewer, this is probably the problem. It is not very good at recognizing various video codecs, but does fairly good at audio ones. Try downloading VLC free viewer. It is no cost and works well.
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
What cable for Gateway FPD monitor to Dell Dimension 2400 compute
You can either use a dvi or vga cable, for more info go to http://service.gateway.com/s/Manuals/Monitors/8511253.pdf
Yellow blue green rectangle in the middle of computer screen the says 100%...cursor scrolls under this rectangle.
its an issue with the monitor vga cable the monitor cable is unplugges or there is and issue with the graphic card if u have or u can try to replace the monitor .
1helpful
3answers
Web cam not working with Skype
It sounds more like you need to updated your flash player software.
Go here and install the latest version of Adobe Flash Player restart the browser and try Skype again >>>>>
http://get.adobe.com/flashplayer/
Regards.
Washed out monitor when viewing most web pages
exchange your dell monitor to gateway monitor.If the monitor from dell showed the same problem when you connect it to gateway. you must install video card driver. and if the monitor from gateway showed the same problem when you connect it to dell adjust your contrast to full and the brightness to 50% and adjust the colors to 100%
2answers
I have a new Dell Studio 540 computer and I'd like to hook it up to my Gateway EV910 monitor. I connected everything correctly. The monitor has power, turns on to the monitor self test screen where it...
You dont need to install a driver for the monitor. The power save mode message appears when the monitor is not able to get a signal from the computer. Make sure the the vga/blue cable is securely plugged to the back of the pc.
note: Inspect the back of your studio. You may have two blue ports where you can connect the monitor, if you do, connect the monitor to the one at the bottom half of the computer.
2answers
Monitor display problem
Do you have the right display drivers for your video card?
You might try playing the movies with a less cpu hungry
player like vlc player to see if low cpu speed is the cause.
http://www.videolan.org/vlc/
36helpful
20answers
Display driver r300
Solution #2 (April 15th 2008) fixed it for me. Very easy to do and my Fujitsu Amilo whatever plays everything fine on full screen again. Thank you for your help.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
