Televison & Video Logo
John Warren Posted on Apr 27, 2012
Screen will not turn on - Akai PDP4295ED 42 in. EDTV-Ready Plasma Television
My samsung tv turns on but only white screen appears
You can try.. turn on the monitor if it just shows the white screen then turn it off then turn on instantly. Even then, if the screen continues to be white (blank) then turn off the screen, unplug the monitor then again plug it after a minute and check.
1helpful
Why does my screen not turn when I turn the phone ?
You have deactivated the screen rotation option.
Pull down your screen, press on the "more buttons" on your top right if you have to and press the "screen rotation" button do it turns active.
I have a Haier flat screen tv it turns on but the screen won't turn on thank
The power button might be stuck
12helpful
4answers
Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
My main screen Doesn't Turn On
There is a power switch on both units. The second screen will get power if the power switch is turned off on the main unit.
Screen turn to white & cant recovery the system
I would reinstall windows sounds like the update corrupted it.
2answers
My ds will not turn on
It sounds like one of you're screens has broken. What you have discribed is generally what happens one either the top or bottom LCD screen has broken.
If it is the top screen the bottom screen will flash for 1/2 a second and the DS turns off.
If it is the bottom screen the DS should still turn on but with no reaction from the screens. (the Ds will shut down immediatley after turning on)
My motherboard isnt turning on
my motherboard is connected correctly but when i turn it on, the screen remains off and i put the bios_wp thing on the motherboard correctly but it still wont turn on and the processor fan turns on but nothing appears on the screen and the screen works well....same as my problem did you get then solution
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
