I got my self a nikon n2000 today, for $20 without a lens or a film. When I buying it from the fellow, he had the camera on and pressed the shutter button to make the shutter do up and down. I brought it home and took out the batteries for inspection, now i put the batteries back in and have tried to slowly touch the shutter button, but i see no led light any where. please help me out.
It is better to read the instructions about the camera and use it Film Direction Course In Hyderabad Glitters India
The camera should operate perfectly fine without a lens. It should also operate perfectly fine without film (other than for not taking any pictures, of course).
I know this is stupid, but make sure the batteries are inserted in the proper direction. Then make sure the film advance mode selector around the shutter release button is not in the "L" position. L is for Lock, S is for single-frame, and C is for continuous.
If you need a manual you may download a copy here.
SOURCE: Nikon one touch zoom 90 camera
I bought this camera at Value Village for $1.99. It came up with an E. I assumed this was an E for empty. I loaded a film and it is fine. [email protected]
SOURCE: Nikon N5005 - No Shutter Release
The lens aperure ring must be set to the highest number, ( IE, smallest aperture, f22,f32 ) for the camera to work in full auto. Also, with the ASA set to DX, the camera will not release without film.
SOURCE: camera won't take a picture
Try these steps:
Set camera into Manual Modes:
ASA/ISO: 200
Shutter: 125
F Stop: 4
Lens: set to M, not S or C
Now press the shutter button.
[email protected]
SOURCE: Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Thank you so much guys, ill try all try the solutions out.
so will the camera actually turn on without film in it and without a lens on? I don't know how the fellow who sold it to me had it so the shutter was releasing without film :S
I think I need to see good dominant industry
