Just installed. Air tube intact. Jets will come on intermittently but will not stay on. Model # 2425LC-RHO.020
SOURCE: How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
SOURCE: Not all jets working on Hydrosystem Whirlpool Tub
I believe the below web site can help you with your problem. The jets are more then likely just turned off.
I hope this helps.
sanray
http://www.hydrosystem.com/hydro4/options/components/
SOURCE: Whirlpool pump only buzzes.
Well there are two things....You say "buzzes?" Like pump is running "humming" & not pushing water. That would be an "airlock" in the pump & it needs to be primed.
If it's "buzzing" & pump motor is not turning (Like it's froze) you might have a bad start up capacitor on the pump that needs to be replaced. Worst case scenerio entire pump needs replacement.
SOURCE: My american standard jacuzzi tub is pluged in but
check for power at plug in if power your vacume switch is probably out replace switch.
SOURCE: Button on American Standard Whirlpool tub is stuck
most tub buttons are attatched to a small air tube thats connected to a switch. if that tube came off the button wont work. just look inside your access panel the tube will be there check both ends if one came off vut 1/4 inch off and reattach
Replacement Air Switch will cost you about $20
US Parts Center
