Experiencing the same problem with my Minolta Maxxum 7D as you all have and after spending countless hours searching for a solution, with none available, I saved the cash and sent my camera to get repaired.(THAT WAS 3 YEARS AGO ) WOW!! what a joy it has been using this marvelous piece of modern ingenuity.There is no other camera like this.It is second to none!
SOURCE: Minolta Maxxum 7D Lithium Battery Replacement
To change this battery you need to dissasemble the back of the 7D, the metal frame behind this one, the front and the right cover and the PCB that support the compact flash reader/writer.
You can see the top of the battery if you remove the compact flash card and look right on top of the connector. The silver rounded portion behind the connector is the battery (5mm diameter soldered on the back of the PCB).
This is quiet difficult job, wit a few delicate connectors, and the flat cable coming from the gyro near the lens is very difficult to reconnect.
Who did you send your camera to? I want mine fixed
