I received a message in the window of the printer that the yellow ink cartridge had to be replaced, so I replaced it with a new one. Now the message says that the yellow ink cartridge is missing. I have replace the yellow print head, problem not solved. I put in a different new yellow cartridge, problem not solved. Need some help with this one. IT guys claim they have no idea what the problem is and gave me a copy of the manual. I'm at a loss. I turned it off and on, unplugged and replugged everything. Nothing.
SOURCE: Replaced Yellow print cartridge and still get the message
This is a common problem with compatible cartridges where the chip on the cartridge is faulty, missing or is not making contact correctly with the printer cartridge connectors. The first thing to do is make sure that the plastic seal has been removed from the chip and that it is free of any residual adhesive etc. You can clean this with a cotton bud soaked in isopropyl alcohol or VCR tape head cleaner. DO NOT USE SURGICAL SPIRIT or any other cleanser as this will either leave a residue itself or damage the plastics and rubbers in the printer.
Once cleaned reinsert the cartridge and try again. If this is still unsuccessful the best solution is to return the cartridges to the vendor where you bought them and get another brand of cartridges or use genuine original cartridges. When you find a reliable manufacturer of cartridges, stay with them. Don’t forget to clean the print head and realign & recalibrate the printer at every cartridge change for optimum results. Also make sure that you use high quality paper for the best images results.
If you have colour or photo paper loaded in the Main tray when you align the printer, the alignment might fail. Load unused plain white letter or A4 paper into the Main tray, and then try the alignment again. If the alignment fails again, you might have a defective sensor or ink cartridge.
SOURCE: I have a HP CP1700
Make sure that printer ask for ink cartridges.It can ask for yellow and magenta print heads!!!Check this again and if need replace the print heads.
SOURCE: HP Color LaserJet 2840 keeps showing 50.2 Fuser
The fuser is the heating unit near the paper exit, and that error means the lamp is burned out, the overtemp sensor is out, or the thermistor in the fuser is bad. About all you can do is replace the fuser. www.precisionroller.com will have a new fuser for you.
SOURCE: Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
SOURCE: I have a HP Photosmart
An '0x ...' Error Message Displays on the Front Panel When Printing HP Photosmart C5380 All-in-One Printer - HP Customer Care (United States - English). If
you need more help come back. Post
/ thumbs / testimonial are welcome!
