Nothing has been spilled on keyboard. All other keys are working.
You will need to replace the laptop keyboard, go to www.ebay.com Type: make and model of laptop and refine search to keyboard.
SOURCE: How to clean coffee spill from Toshiba laptop
Have you tried to open a laptop? If not, try to go to service center it might causes more damage.But if you can, use a tissue and a ligther fluid to clean the keyboard membrane. Dry it well so that it cant causes shorted.... Thank you for using fixya....please dont rate me if you are not satisfied with my suggestions.
SOURCE: Spilled liquid on laptop keyboard
Search for a keyboard on eBay. Should be about $5-15. Type in "(model name) keyboard."
SOURCE: Spilled juice on my H P Pavilion laptop keyboard, keyboard is not working at all. Please help!
Do you have an HP Accidental Damage extended warranty? If you do, you can call HP's tech support and get it fixed/replaced.
If you don't have the extra warranty, you can try to carefully pop the keyboard keys off and carefully clean underneath as the contacts below the keys are possibly stuck in the down position.
You may have to take it to a service centre and have a technician open up the laptop and see if it can be cleaned and try to "unstuck" the keyboard keys.
SOURCE: toshiba at the rate and invertd comma keys are interchanged
Dead easy, go to the Control Panelselect region and language settings.
On opening you will get a pop up with 3 tabs
!st tab change region to UK
2nd tab click details and change all options to UK
That's it done.
SOURCE: spilled water on keyboard. a few keys don't work
If this problem occurred recently you might still be able to save the keyboard. However, it is a painstaking method of popping out each of the keys that are not working and cleaning them off (preferably with some contact cleaner) and making sure that there is no corrosion trying to form due to the moisture. Be careful when prying up some keys as some keyboards (especially laptop keyboards) are hard to put back if you don't have the right tools or the know how. I suggest looking up keyboard removal techniques based on the brand of your keyboard/laptop.
Good luck...
