Other wireless device connect no problem. If I hard wire I can connect to network and printers. if I log in via guest on router, I get internet, but no local hardware (printers, shares, etc..) Wireless says it is connected, gives me an IP address. No Local network access and no internet
Try switching the way you connect the wireless. On your laptop there are 2 different ways to connect, one using the the client application that goes with the wireless card, and the other way uses windows to manage and connect to the wireless. Switch them out. If you are using Windows, then use the other or vice versa. Open the software that came with your wireless card it should be on your desktop or in your program list. Click Start/Programs and look for it. For example it might be something like Atheros. Open it and look for a place or check mark on something that says: Let This tool Manage the Wireless, or Use Windows Zero Config to Manage the Wireless.
SOURCE: Dell Laptop is not pulling IP address
Click on Start - Control Panel - then Network Connections - then righr click on your Wireless Network connection - click on Properties.
Then in "This connection uses the following items, scroll down to Internet Protocol (TCP/IP) and click on Properties. Under the General Tab make sure Obtain an IP address automatically and Obtain DNS server address automatically are selected. Click OK.
If you do not see TCP/IP in the Wireless Network Connection then click on the install button and then install the TCP/IP driver.
IF TCP/IP is OK then
Before you do the following, turn off or disconnect the power to your wireless router, wait for 1 minute before connecting the power again. Wait till the LED lights indicate that it is on line again and the wireless is on then :-
Click on Start - Control Panel - then Network Connections - then righr click on your Wireless Network connection - click on View Available Wireless Networks
Do you see your wireless network (ie. your wireless router)?
If so click on your wireless router and then click Connect.
You can also click on Repair to try to reconnect to your wireless router.
Let me know if it works.
SOURCE: Laptop can't aquire IP address
I had the same problem, went to Microsoft and found this solution on line.
1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s then click ok.
2. Double-click Wireless Zero Configuration.
3. In the Startup type list, click Automatic (if it shows Automatic already, change it, then put it back to Automatic, that will activate the Apply button) then click apply.
4. In the service status area, click Start, and then click OK.
That fixed it for me after fighting it for about a month.
SOURCE: Won't refresh IP address?
Clicking repair normally sets incorrect ip addreses to your router requirements. Firstly, dissable your wireless connection, as your pc will still be trying to connect to the router, then try connecting again, your router should automatically assign an IP address to your pc. If that fails get into your routers settings (eg type in something similair to 192.168.x.x) x's being the numbers required for your router(see your manual); and have a look at the ip addresses that the router assigns to your pc's, probably on the 192.154.x.x region and write them down if neccassary. Then open up your wired cards properties(control panel- network connections- local area connection icon) and click on 'internet protocol tcp/ip', then properties and then click use the following IP address and type in the same numbers as your router range except for the last figure as this must not be same. You must also make sure the Subnet Mask numbers are the same as this is the route your connection follows to the router. Sorry it's a bit long winded but theres no shorter way round it.
SOURCE: Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
SOURCE: My laptop will not connect to my wireless connection
To turn the wireless radio on and off, press FN + F2, if it still won't connect the adapter will probably need hard resetting.
This method will hard reset the wireless drivers back
to
default settings, but before you perform this remove power from the
modem and router for 2 minutes reconnect power and wait another 2
minutes for them to settle down.
Right click "computer" select "manage"
and then "device manager", a list will populate, then click on the + sign next to "network
adapters" and right click on the wireless adapter and "uninstall" the
device, reboot the PC and wait for windows to detect the wireless
card and install the drivers for it, this will appear in the system
tray (bottom right hand side) when its done try to connect again.
Good luck
