TV goes half black picture and I have to shut it off. It will play for a short while and it only happens when its hot outside
Half black? top/bottom or left right?
The set is rather old--a old trick to use is to connect a fan to the rear of set with the back off--it may extend the life of the set and give you some more use out of it.
I have seen a lot of these sets and never one with the problem you describe. If only a picture top or bottom is missing it may be vertical or if you are seeing what looks like a full picture with top or bottom black it is a Blanking problem--may not be easy to find...........
SOURCE: no sound or picture
jerel,
Please provide accurate info for best solution = on back of set =
Model # , service # , chassis # , Mo / Yr built............
Stopped playing = Dead ? ....no sound , no picture, no green
power led on front??...........................Help ! Let me know..T.
SOURCE: 52 inch RCA big screen
check all connections and different sources(dvd, vcr, antenna) to make sure that it is the tv. otherwise i would say call a technician because you could be in for some extensive troubleshooting
SOURCE: 52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
All connections were checked. This doesn't happen in the winter time at all. Only when it seems to get hot outside. Is there something burned out that I can replace on this unit? Or is it just best to now replace the old tv? Its a 2001 model P52939, serial 137651043 RCA 55in projections screen tv.
