Garden Logo
Anonymous Posted on Apr 24, 2012
Gas leaking from bottom valve and getting in oil on a John Deere 110 17.5
Gas leaking in the oil and out of the bottom valve. on 110 17.5 riding john deere mower.
Anonymous
Level 3:
Brigadier General:
  • Master 6,468 Answers
  • Posted on Apr 28, 2012
Anonymous
Master
Level 3:
Brigadier General:
Answers
6468
Questions
0
Helped
2131438
Points
13357
Sounds like the needle valve in the carb is not seating also check the oil gas over flows from the carb into the oil change it a couple times
5 Related Answers
rjnworbnhoj
  • 142 Answers
  • Posted on Sep 20, 2008
SOURCE: John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
Phil Rivera
  • 83 Answers
  • Posted on Mar 30, 2009
SOURCE: belt broken on riding lawn mower (john Deere LT
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
This link will send you to the illustrated parts list on the john deere site. It shows the belt routing in the part diagram. Hope this solves your headache.
Anonymous
  • Posted on Apr 08, 2009
SOURCE: illustrated parts list for john deere 102 riding lawnmower
Go online to www.johndeere.com click on residenial tractors,then click on services and support. You should be able to get an answer there. Otherwise contact them through email.
Anonymous
  • 86 Answers
  • Posted on May 09, 2009
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Anonymous
  • Posted on Jun 02, 2009
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
17.5hp briggs and stratton engine on my d105 john deere riding mower has a lot of gas coming into the oil.
The carburetor inlet needle valve is not closing. Could be debris in fuel, bad float, stuck float.
The fuel solenoid prevents afterfire by blocking fuel from the main jet, it does not shut off fuel into the carburetor bowl.
John deere kohler engine leaking oil bottom bolt of fuel pump
a new gasket and sealer
end.
no engine model told so exact answer will be HARD.
Gas is getting into oil in my John Deere riding mower la 135
It sounds like you have a serious engine problem and I suggest you stop trying to run it as you may cause a lot more damage. Take it to a John Deere repairer who will be able to find out what is wrong with it.
730 john deere crankcase full of gas after sitting 2 years what repairs
make sure it hasn't damaged the crankcase seal on bottom drain and replace the oil. it is full of gas because the carburetor failed. put a rebuild kit in the carb. (needle and seat). should stop the gas from leaking in. should be fine
2answers
I have a John Deere LA105 and it is getting too much gas and coming out of the carburetor flooding it,I checked the float and it is fine,,,what else could it be?
I'd look at the valve needle and/or needlevalve seat. One or both maybe corroded or obstructed from free movement.
What is my problem with my mower oil too full and has gas in it.
Your rings on your piston cylinder provide a seal between the piston and the cylinder wall. If the rings leak, gas from the cylinder can leak into the crankcase. Plus you will lose compression. May need to take it in and have a pro look at it.
1helpful
My lt 133 john deere mower has gas in oil and back fires. runs 5 min and stops.
It's going to need a carb kit to fix the problem. Make sure your gas cap is venting ok, because gas expands in the summer and can force gas to pass thru carburetor and flood the cylinder then passing down into the oil. Depending on the age of your mower, the carburetor may have a gas shutoff solenoid on the bottom and this may have malfunctioned. Another is a bad float or needle valve which a carburetor kit would fix. A needle kit with bowl gasket may be all it will need. Hope this will help.
John Deere LA110 riding mower has gas in the oil
Try stripping it down and having alook sounds like the piston ring has snapped and is pumping gas into the oil that would explain why the oil is coming out the the exhaust the black smoke is just oil burning up ou also might want to clean the carb alittle too.
Blue smoke hard to start no power john deere 2140
Sounds like you have a piston ring ring problem or valve guides worn. Both will cause blue smoke and hard to start. If you don't know how to do a leak down test then you'll have to give it to someone who does. The leak down test will determine if it's the rings or the valves. Also, check to make sure you don't have too much oil in crankcase
Good luck.
skidooer
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
