Im having trouble formating my tecra m1 i dont know what are the steps a-z pls. i need help. formating desktops is easy for me, laptops is very hard to format
SOURCE: BIOS is not appearing in Toshiba tecra laptop M1
You can enter BIOS by holding down F2 after power on. Hope this helps.
SOURCE: ethernet controller driver&wireless driver for tecra m1 notebook
you install internet explore or install new operating system you chak you lan show ip address
SOURCE: i don't have no driver from toshiba tecra M1
Toshiba is very good with the tech support. I had the same problem and they sent me the original installation disk that came with the computer. these disk will look at your system and install the needed drivers. It will also restore the computer to the original configuration when it was first purchased. If you use this option you will loose all that is in the computer now. YOu must backup anything you want to save. I do this on my own computer when it gets to the point that nothing is working properly. I have also found original disk on Ebay for older computers.
SOURCE: i need vga for my toshiba tecra m1
check out this link u will find ur display driver
http://driverscollection.com/?H=Tecra M1&By=Toshiba&dpage=7
