Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up. Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off
Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired
SOURCE: chuld unlock
to unlock the parental control on a Telefunken TV that has a blue screen and a red padlock on the top left hand side, hold down the display button on the remote for 10 seconds and it works
SOURCE: Need to unlock Centrex TV model CTT6809SF
Hold down the plus key (bottom right) for 4 seconds
SOURCE: child lock has TV locked
Well after spending about 45 mins on hold and searching the internet for the last 2 days the resolution to this issue is to hold the display button down for 3 secs .... Yep thats it Hope this saves someone some time --Brian
SOURCE: unlock durabrand tv model dbtv1024
the chroma section pcb (cnnected to the back of picture tube) parts , some of it has loosen resolder it ......
