Try this:
https://tails.boum.org/doc/first_steps/usb_reset/windows/index.en.html
It worked for me.
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
if still no joy
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps you
i try everyting that you mention above still not work my all data can't show dive shows that my data in it but can't show .help me....
i try everything that you mention still need help its not working drive shows that my data in it but not show it when i open ....
you might have to continually alternate chkdsk utitility and restore defaults orhttps://tails.boum.org/doc/first_steps/u...
SOURCE: My kingston DT 101
Try to download theses tools, they may help you to format your flash drive.
http://www.ridgecrop.demon.co.uk/guiformat.exe
http://fichier2.easycommander.com/clean/Fat32Formatter_1.0_5730.zip
SOURCE: How to remove write protection
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value. If you are running a Windows XP OS then you might be able to:
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
