Pentium (R) dual core E5200 2.50GHz...sound driver
Drivers for Intel products are available from the Intel website www.intel.com However this is a system level problem and so the drivers for your sound chips are most likely to be found on your computer manufacturer's website or you motherboard manufacturer's website, or if your sound card is external to the m/b, the sound card manufacturer's website. In any case you will need your operating system details.
15.April.2014
SOURCE: chipset driver needed where to get it or a site to download
You should be able to download this driver from your motherboard manufacturers website. Just click on the support link and lookup your specific board model #. Hope this helps.
SOURCE: How can i upgrade my intel(r) pentium r dual core 2.8 processor.
http://www.mercury-pc.com/p-mainboards-list.php hello, try this link to id the board, as you will see 5 945 mercury mainboards. if you pick the one you have, like 945gcm for example, you can find out the fsb, cpu, memory. if you still need help, reply please rate this solution and good luck!
SOURCE: Upgrade from pentium 915 D to dual core
The pentium d 915 is a dual core processor, albeit a bad one. You should check google for info on your motherboard to see if it supports Core 2 duo's/ Core 2 quads. I have an E6600 overclocked to 3.0ghz and it still plays games perfectly paired with my 8800gt 512mb and 4gb's ram. I definately recommend upgrading to a core 2 duo. I used to have a pentium d 915 and it was bad for gaming and the e6600 blows it out of the water. You most likely wont find the e6600 anywhere as it is nearly 3 years old. Look at sites such as toms hardware to find a good core 2 duo.
Good luck- an t-adh leat!
SOURCE: I need intel pentium dual core E2180 mother board
E2180 is not the motherboard ,it is processor model no. for getting motherboard drivers kindly tell me the motherboard manufacturers name or you may directly visit there site else i am providing you a link where you will find exact match to all of above
LINK
click on the link and enter the name of motheboard you will get what you are looking for
thanks and regards
kindly rate this solution
SOURCE: audio driver of Intel Cpu Pentium Dual-Core E2180
look at the brand of your mainboard then download the driver from ther website.
