My dimplex electric heater is tripping the electricty supply
  • 31 Answers
It louds like a limit switch is tripping because something is getting overly hot,the limit switch is a safety device looks like a little black part with a push reset button in the middle
Posted on Nov 16, 2008
6ya staff
SOURCE:
Need replacement grille for Dimplex floor drop-in heater FFIH15A31
Get the dimensions of grille and contact dimplex, or plumbing & heating supply store for new grille.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Apr 15, 2014 | Dimplex FFIH15A31 Electric Heater
Anyone know where I can buy part number 2800090200RP besides Dimplex? it is a small on/ off switch for a electric dimplex small stove model number 6901050100
Some hardware stores, electrical supply stores, radio shack, are a few places I would think of trying. Take old one with you to make sure same amperage/voltage rating.
Sep 15, 2011 | Dimplex Compact Electric Flame Stove...
Hi, I don't know what the reset switch on my dimplex ofc2000ti looks like, anyone any ideas? Power to unit but not heating up, all connections inside fine. Hopefully it overloaded and tripped.
Turn the Master On/Off Switch to OFF and unplug the unit from the wall receptacle. Leave it unplugged for 12 - 15 minutes. That should give it enough time to reset itself. Then plug it back in and give it a try. Also, make sure that the wall receptacle is working properly and hasn't tripped the circuit breaker in your home's circuit breaker panel. If it did, something is seriously wrong electrically, with the heater.
Hope this helps you solve the problem. Please don't forget to rate my response to your question.
Thanks!
Mar 25, 2011 | Dimplex OFC2000TI Heater
Light working but when the heater is turned on the breaker trips
The heating coil in a lot of this style heater is a springlike coil mounted in insulating holders. I am not sure about your particular heater but what has usually been the problem with these heaters is that the coil has broken and shorted to earth. Turn off power at the trip and remove the heating element cover and the electrical cover on the heater. If you can not see any physical damage put an ohm meter between the element and the earth screw in the electrical connection box. If the meter shows any continuity the element is faulty and needs to be replaced. Hope this is of some help.
Regards,
Andy.
Jan 03, 2011 | Dimplex DF3003 Electric MidSize Heater
When you turn on the drier it trips the electricty. there is power in to the power switch but when you turn the dial it trips the fuse box. the model is TC7103W
an electrical earth leakage will cause the trip. possibly the the heating element. but the motor or wiring fault can do it. you could try disconnecting the heater if the electric stays on. then change the element.
Jul 22, 2010 | Zanussi Dryers
My dimplex night storage heater is not heating up, the power supply is fine. Is there a fuse or trip switch anywhere
thermal heat line melted just 2years 3 weeks old should this heater have been recalled some were put in by the warm front scheme frozen old age pensioner
Dec 19, 2009 | Dimplex Heating & Cooling
Heater in fireplace keeps tripping and has to be unplugged to reset (new unit)
heater is drawing to many amps for the heater to run correctly check the circuit it is on and possibly move to a different location on a circuit that has more amps from panel box.
Dec 10, 2009 | ACE Dimplex (r) Compact Electric Fireplace...
15 Amp circuit breaker keeps on tripping , as as
breaker tripping right of way means bad breaker or dead short. which means something has burned out or is wired incorrectly
May 13, 2009 | Heating & Cooling
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
