Ovens Logo
Posted on Nov 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Amana gas stove acf3325ac f2 code
Have had problems inthe past few years and have replaced the circuit board behind clock 3 times
getting the f2 code again , the stove does preheat and heat for a while but then shuts off displaying f2 code . I can turn knob back to off then the stove will turn on again for a while
please help .
just bought a now board replaced it but still same problem.
Previously the f2 code would not turn off.
Anonymous
Level 3:
Genius:
  • Master 1,239 Answers
  • Posted on Nov 16, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1239
Questions
8
Helped
407287
Points
3279
HI The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
PLEASE RATE IT............................
  • Anonymous Nov 25, 2008
    hi sir i given a correct soluution.if you want contact fixya support  about this.please change your rating i will affect my rating badly.please change it..............................please
KitchenAid Range/Stove/Oven Model KGRT607HW4 gas range Error message F2:E5
Question edited for clarity. Please always include Maker and (what it is)'.
Mainboard control Issue. It can sometimes be fixed with a Power Reset.
F2 E5 - Electric Range - Product Help
KitchenAid https://producthelp.kitchenaid.com > ... > Starts with F2
Dec 14, 2019 - Power unit up by turning on the circuit breaker(s). Monitor the oven for one (1) minute to ensure the error code does not display again. Verify ...
Missing: KGRT607HW4 ‎' Show results with: KGRT607HW4
F2 E5 - Wall Oven - Product Help
I have a Kitchen Aid oven that is giving me an E5 and F2 and
JustAnswer https://www.justanswer.com > Appliance Repair
Aug 16, 2020 - Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if ...
1 answer · Top answer: Manufactured August 2006. Your friend was correct. Only 14 years old
What are error codes E5. F2 - Q&A
Best Buy https://www.bestbuy.com > site > questions > question
Jan 17, 2019 - F2-E5 - Cancel Key Line Open - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Dec 17, 2023 • Ovens
tip
Fault Codes for Admiral Range/Stove/Oven
There are many fault codes for different ranges, ovens and stoves. These also are different for each manufacturer or brand. To see what the fault codes are and what they mean for the Admiral brand you can check this chart. It also will give you a short explanation and repair for each code.
Some of the repairs are simple and some of them are much more difficult.
Most parts are easily bought online. Check the link below to another tip I wrote about how to buy parts online.
Fault code What is wrong What to check or repair
F1 Defective touch pad or Replace touch pad or clock assembly
Membrane this also can be called the ERC
F1 Watchdog on board Replace the touch pad or ERC
F2 Oven too hot Replace the relay board or oven temp
sensor
F3 or 4 Open or shorted oven Replace oven temperature sensor
Temperature sensor
F5 Hardware and watchdog Replace clock assembly or ERC
circuits disagree
F6 Missing AC signal Check for proper voltage
F7 Function key shorted or Un-stick button or replace touch pad
stuck button /ERC
F8 Analog/digital trouble Replace clock assembly/ERC
F9 Door latch trouble Check door lock circuit or ERC
F0 Function key stuck Replace touch pad or ERC
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
on Feb 18, 2010 • Ovens
My parents are getting an F3 on their Amana gas stove. This stove is about 9 years old. Not sure of the model. The burners are working fine, but they cannot use the oven. Any ideas? Many thanks!!
Hello & Welcome to FixYa
F3 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Oven goes off and f2 or f5comes up , what does this mean?
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F5 Hardware, safety circuits disagree Replace Clock
Error codes for American stoves with service manuals and more HERE
Thanks for using FixYa
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
2answers
Error code E0 F2. Now oven will not come on, but stove above works.
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock).
7helpful
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 • Ovens
1helpful
2answers
Whirlpool oven RBS245PDB2 - Was getting the E3 F2 code and just replaced the control panel. Am now getting a new error code - E0 F2. Any thoughts?
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$!$
2helpful
F2,F5,F7 message
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Top Amana Ovens Experts
ADMIN Andrew
ADMIN Andrew
Are you an Amana Oven Expert? Answer questions, earn points and help others
