Nikon Coolpix S3000 Digital Camera Logo
JM Kurek Posted on Nov 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i use another usb wall charger for my nikon coolpix s3000 or can i only use the one that came with it?
I have the cord for the camera, but cannot locate the wall adapter part. Can I use another USB wall plug (like a universal one or Apple wall USB jack)? When I plug in the camera, the green light flashes slowly, then rapidly, then ceases. I always have problems with these cameras, but when I return them, I have to get the same one
Cherwally
Level 2:
Sergeant:
Habit-Forming:
  • Expert 156 Answers
  • Posted on Nov 19, 2017
Cherwally
Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
156
Questions
Helped
62197
Points
619
Check the output Amperage on the original dedicated charger and what you wanna use as replacement.
Some devices does not like over amperage and others the under amperage...
Otherwise it shouldn't affect anything if you use other chargers.
5 Related Answers
fotomohamed
mohamed salim shaikh
  • 321 Answers
  • Posted on Jun 18, 2009
SOURCE: My Computer doesnt detect my camera
it wont show on window2000 it will show only in windowXP for window 2000 u need drivers cd of nikon coolpix install that 1st
Anonymous
  • 71 Answers
  • Posted on Jul 08, 2009
SOURCE: Computer won't recognize my nikon coolpix 4600
You need to give some additional information. What OS are you using? USB, with all newer OS's is native and you shouldn't have to have any special drivers or software to get the camera detected by the computer. Simply plug it in and go to "My Computer" and it should be seen. If this is not the case, start with the physical connections first. Check the USB cable between the two. if a 2nd cable does the same thing, check a different device with the same cable and connection port on the computer. If the port works, and it recognizes another device, you have to look at the camera. If it doesn't recognize the 2nd device, look at the port on the computer. If ANOTHER port doesn't work, go into the Hardware device manager and ensure that USB ports have not been disabled. If it's the camera, chances are the port has died. If this is the case and you don't want to trade the camera in, try getting a $30 card reader and place the data card into the reader to ensure that the card isn't the issue. The reader will ensure that you can transfer the images and will also save some wear and tear on your camera.
  • 102366 Answers
  • Posted on Jan 05, 2010
SOURCE: Can I charge Coolpix S210 via USB cable and wall outlet?
No. In order to keep down the size and weight, the camera does not include the circuitry needed to charge the battery.
Anonymous
  • Posted on Mar 22, 2010
SOURCE: nikon coolpix s210 will not connect to mac
I have a Intel Mac Powerbook running OS10.5.8
On a coolpix 100, the default setting is that the camera is charged by the computer through the USB cable. You need switch that OFF.
While the camera still does not show as usb device, you can access it through the Nikon transfer program AND through iPhoto
ez-pics
Anonymous
  • Posted on Jul 02, 2010
SOURCE: when i plugged it in for the first time to
I faced the same problem too. But I realised that after plugging in the adapter and connecting it to the camera, you would need to press the power button but not turn it on.
2answers
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
WHY MY NIKON COOLPIX S3000 FLASH NOT WORKING?
okay let mi think....
you cant charge a nikon camera via usb port the usb port is data only
please reply and try to use a nikon coolpix s3000 charger
2answers
My Nikon wont turn on or charge
You may need to purchase a new battery for this. Or there could be a problem with your battery charger or power cord. Replacing the battery and charger is the simplest solution.
Something like this:
http://www.amazon.com/Nikon-Coolpix-Digital-Camera-Accessory/dp/B0040996PM
M using Nikon S3000 digital camera . but i don't know how can i charged my camera
Hi there just remove the battery and fit the battery on external charger which is came with you camera pack. Or you can charge your battery throw USB charger if you have the cable. Thanks.
3helpful
How do you charge a nikon coolpix s3000?
It comes with a wall jack that powers the included USB cable. Plug the USB cable into the wall jack and into the camera to charge. You can also charge from a PC if you connect the USB cable to the PC instead of the wall jack.
Hi My digital camera the Nikon coolpix s3000 kept flashing batter exhausted but it wont charge by the computer. How do i fix or charge my camera?
Not all computer USB ports put out enough current to charge batteries, especially if you're going through a hub. Try a different USB port if one is available. Otherwise, plug the supplied AC charger into a wall outlet and use that.
3helpful
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
