Ryobi Multi-Volt Battery Charger Logo
Posted on Nov 16, 2008
Ryobi battery charger
When the dead battery is inserted in charger, green light comes on showing fully charged, instead of red.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6300
Points
6
The same thing happend to my charger, i let it cool down and now the green light goes off and shows red again. thanx for that post
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
860
Points
Either the battery is hot from use or has been in the sun, let it cool down, then try again.
Ryobi 18V Battery green lights stay on, fully charged, won't power drill
Seems batteries have completed their normal life and require replacement. Keep in mind that when batteries are exhausted, their voltage remain normal but loose current. It seems that batteries do not sustain current i.e. have become un usable.
1helpful
2answers
Green light on new Ryobi charger flashing when trying to charge battery it that normal
Yes, the green light flashes until the battery is fully charged on Ryobi chargers. This will change to a solid green light when the battery is fully charged until the charger goes to a power-saving mode. Not all of the Ryobi chargers have a power-saving mode. However, for those that do, the green led will dim over time and then brighten and dim slowly again in this mode.
My Ryobi charger, model P113, actually has a key for the LEDs on the unit on the left of the battery port. The manual for this charger is here: https://manuals.ttigroupna.com/system/files/5495/original/P113_192_trilingual.pdf?2011 . Ryobi has many of their manuals on their site. Look up your charger/tool here: https://www.ryobitools.com/power-tools/support/manuals , Home Depot's web site also has many of these manuals on the product site for the tools that they sell.
I hope this helps.
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
My nokia bh503 headset not charging
Leave it plugged in for 4 hours. Yello should turn red then green when fully charged
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
When I put the 18V battery in the charger, the green and yellow lights come on and stay on, instead of the red. What's up?
i always thoiught that when you light is green it is fully charges yellow is weak and red is dead
maybe you have it reversed check it again also make sure that (altho hard to do) the battery is in right
2helpful
Green and red light comes on when i put battery in charger what does that mean?
Here is the manual:
http://toolboyworld.com/eBay/Ryobi_P120/P120_566_eng.pdf
Red = quick charge
yellow = evaluating
green = charged
If battery pack is within normal temperature range, the red LED on charger will come on.
Red LED should remain on for approximately 1 hour then the green LED will come on. Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode.
12helpful
Green & Yellow light on 14.4V charger
It sounds like your battery is bad.
replaced.
3helpful
2answers
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
