Hi,my laptop will not charge properly something wrong with laptop because i have bout 2 new chargers that work perfectly and bought a new battery over a week ago which works fine,the charger only works when u press real hard into the socket or it has to be but at an certain angle to charge and even doing that it chargers for 2-3 mins then goes off then charges again then goes off. could someone help me please???/ e-mail:[email protected]
SOURCE: I have an Amilo A1645,
your problem is the power supply is bad, that's why it won't run without battery, and also, the old battery you replaced is probably good
SOURCE: My Fujitsu Lifebook AH530 says
That's a brand new machine.It should be under warranty.Contact Fujitsu support using the information at the following link: http://solutions.us.fujitsu.com/www/content/support/contact/index.php
Otherwise, you might want to return it for replacement ,repair, etc. Sounds like it has a manufacturer defect.
SOURCE: My Fujitsu Lifebook LH 531
IT WILL BE HAPPENED WHEN CHARGE IS >=90%.. WHEN UR CHARGE IS LESS THEN 90% THEN IT WILL GETTING CHARGED..
IT IS ONLY FOR BATTERY LIFE CYCLE..
