How do you rewind spring and reinstall. Must be a secret to this priblem
To rewind the spring is a bit of an art, hook the end of the spring into the stub on the starter, now start to wind each coil into the cover, making sure you keep your thumb on the coils you have wound in so as they do not spring out, otherwise order a new spring which will come pre wound in a keeper to make instalation very easy.
SOURCE: rewind a husqvarna chainsaw pull cord spring
ohh ! yes it can be done But with a lot of difficulty and many zapped fingers as it springs back under pressure
please rate my help++++Thanks for using FIXYA
SOURCE: husqvarna 365 order to install trigger, throttle catch and spring
Here's a link to the husky parts list.
http://www.usa.husqvarna.com/support_manual_search.aspx?webecsearch=10527&O=true
SOURCE: I need to replace the starter spring & pulley
Cb is right, the IPL will help for part numbers and as a guide for assembly.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
This may help too.
Smalleng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
Good Luck
Lou
SOURCE: how do i release the brake spring on a husqvarna
Immobilize the clutch cover (blocks of wood on a flat surface to protect the finish) in a vise or to a work surface,
Use pliers or a crescent wrench and rotate it clockwise until it latches open. This will require some force.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
