2006 Ford Explorer Logo
Posted on Apr 21, 2012
Where is the computer module located at on. 2006 ford explorer
Patricia Mitchell
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 30, 2013
Patricia Mitchell
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3131
Points
2006 ford explorer, where is the computer module located? I lost my keyless entry code and the key when cold doesn't always work. And will the numbers on keylock light up?
5 Related Answers
Anonymous
  • Posted on Mar 16, 2010
SOURCE: where is the computer module to get the 5 digit
How can i do to change the 5 digit entry code for the ford explorer eddie bauer 2006 with engine 8 cyl, 4,6 L
Anonymous
  • 659 Answers
  • Posted on May 11, 2009
SOURCE: replacing the control module on my 1997 ford explorer
the module is located behind the dash just to the left of the radio. remove the two screws below the radio and the dash panel snaps out and you can access the module
Anonymous
  • Posted on Jun 19, 2009
SOURCE: Where is the computer module located on my 2003
open rear hatch ,look to the left panel under side window it is behind there
Anonymous
  • 4669 Answers
  • Posted on Mar 30, 2010
SOURCE: i have a 93 ford explorer 4x4 where is 4x4 module
The transfer case control module is behind the plastic panel above the left rear wheel well
Anonymous
  • Posted on Mar 29, 2011
SOURCE: 2006 ford explorer computer location? I looked
how do you change rear wiper motor on 2006 explorer?
2helpful
2answers
2006 Ford Explorer 4.6 Eddie Bauer Edition. What shows you the outside temp while you are driving?
Did you by chance check for DTC'S diagnostic trouble codes?
Instrument Cluster Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1255 Air Temperature External Sensor Circuit Open Instrument cluster Go To Pinpoint Test E . B1257 Air Temperature External Sensor Circuit Short to Ground Instrument cluster Go To Pinpoint Test E . B2097 Compass Module Failure Instrument cluster Go To Pinpoint Test B . U2013 Compass Module - No Response Instrument cluster Go To Pinpoint Test B . All Other DTCs - Instrument cluster REFER to Section 419-10 .
2answers
2006 Ford Explorer. Intermittent fuel pump issue?
Question edited for clarity.
Question moved to model category.
It is difficult to test things like relays when you have an intermittent fault because it could test okay 9 times out of 10. They are not expensive, I would swap out the fuel pump relay for a new one. If that doesn't fix it, you need and auto electrician with a pro grade scan tool computer. They can record what is happening when things go wrong.
Fobs are not working on my 2010 ford explorer changed batteries and still dont work. what fuse relates to the fobs
Did you try programming the key fob? Your owners manual has this info. I don't know if programming will help or not? Just a thought.
fleet.ford.com should have your owners manual, if you don't have one,you can read it for free.
Also try owner.ford.com
has owners manual you can look at for free.
2helpful
I have lost the only key that I had for my 1996 Ford Explorer 4WD,8CY.My local Ford Dealership said that even if I have the VIN, they can cut me a key because they dont have key codes past 2006!!! A...
Key code for KEYPAD located in drivers door? Ths is located in label Security Module; if need additional details, just contact us HERE.
Good luck.
2helpful
Where is the egr valve on the 2006 ford explorer
i hope that this could help you the EGR valve is the item #7
Item Part Number Description 1 - EGR system module electrical connector (part of 12B637) 2 9E498 Engine vacuum harness 3 - EGR system module-to-exhaust manifold tube upper fitting (part of 9E469) 4 - EGR system module-to-exhaust manifold tube lower fitting (part of 9E469) 5 9E469 EGR system module-to-exhaust manifold tube 6 W506024 EGR system module bolts (2 required) 7 9D475 EGR system module 8 9D476 EGR system module gasket
2answers
2006 ford explorer computer location? I looked behind the seat belt panel on the passenger side and can't find the factory code to reset keyless entry key pad. I see what looks to be a silver module but...
You go to a dealer with your ID ,title and proof that you own it
They will look up your vehicle, and give you the code that comes
with your owners package when new
They should give you instructions on how to change the
factory code. You need to go around back and talk to a tech
The service adviser will waste your time with a dog and pony
show.
2answers
I need to disable DRL in Ford Explorer 2006
Go underneath the hood and find the DRL module in the Fuse Box and just pull it out.
1helpful
Where is the computer module to get the 5 digit entry code for the 2006 explorer
2helpful
2006 Ford Explorer XLT the Blower Fan only works on 4 and 3 Sp
Look under the dash on passenger side and just to the left of the blower motor housing you will see the 4WD control module.Remove the 2 screws holding the module and let it hang down and your resistors are behind this.Remove the 2 screws holding the resistors and remove.
Now I am assuming you have manual climate control and not electonic.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
