Double oven
SOURCE: Need manual
Thanks to an earlier solution by huuum, here's a link to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
SOURCE: Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
SOURCE: maytag gemini self-cleaning oven
heres alink to a manual explaining the self clean operation( its for a gas gemini range, but if you have electric, procedure is the same) page 11
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113P383-60.pdf
SOURCE: F9-6 fault code on maytag gemini double oven range
I waited until the next morning and hit the cancel button. It cleared the error
SOURCE: I have a Maytag Gemini Precision touch 750 series
This sounds like your ignitor has gone out. The preheat will work because the valve doesn't have to ignite to heat to 100 degrees, but whent he unit is ready to ignite, the gas can't ignite it. If you will call or email us, we'll be sure to get the correct ignitor out to you asap so you have your oven orking right away! Thanksgiving is just around the corner, so I hope you get this repaired soon. We hope this helps and we hope to hear back from you soon.
