Water runs out under right side of the doors no mater what i cook,vents aren't clogged has done this even when new. thank for feed back
SOURCE: frigidaire microwave won t turn off
this is a problem with your programme timer these can be expensive to replace and because of the age you will probably be better buying a complete new unit as you could repair it and you could come across other related problems and could end up spending a fortune sorry i couldnt be any more help
SOURCE: GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
SOURCE: microwave not cooking
I would say you have a bad door switch or door switch mount, or your door is loose or out of alignment.
But since it's new, and under warranty, I would contact Goldstar (LG) customer service to have them repair it free.
Contact LG at 1-800-243-0000 or http://us.lgservice.com
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: door is loose, microwave won't cook
The door switch mounts and possibly the door hinges need to be adjusted them tightened.
Unplug the oven, remove the cover if it's a counter top type or remove the grille and control panel if it's an over range type.
Then close the door and watch how the door latch heads on the door mesh with the door lathes and door switches.
Also check the hinges.
If the door latch heads are not activating the upper & lower door switches, then adjustment will be needed.
For many brands, you can find helpful exploded view diagrams and order parts by entering your full model number here.
There
is often a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
Please reply back with your brand and model number if you need more help.
SOURCE: Whirlpool microwave cook light turns on but oven does not work
Check and replace the door safety switch.
