If your Grundig tumble dryer is taking a long time to dry clothes and not getting as hot as it used to, there are a few things you can check:
Clean the lint filter: A clogged lint filter can prevent proper airflow and cause the dryer to take longer to dry clothes. Make sure to clean the filter before every load.
Check the vent hose: Make sure the vent hose is not kinked or clogged. A blocked vent hose can also cause the dryer to take longer to dry clothes.
Check the heating element: A faulty heating element can cause the dryer to not get as hot as it should. You can test the element with a multimeter to see if it is working properly.
Check the thermostat: A faulty thermostat can also prevent the dryer from getting hot enough. You can test the thermostat with a multimeter to see if it is working properly.
If you have checked all of the above and the issue persists, it may be best to contact a professional appliance repair technician for further diagnosis and repair.
no make listed here...I would pull the hose off the back of dryer and see if a lot of air is blowing out of vent. if not, heres your answer a clogged filter area ..if air blowing out leave vent hose off and dry clothes with vent off for one cycle. if clothes dry with vent hose off..you have a venting issue and need your vent cleaned out...
yu may have a bad heat switch but it sure sounds like ur dryer vent is kinked or clogged double check better yet unhook it from the back of the dryer and dry a load of clothes if better ur problem is in that vent
If you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some tihings to check before assuming there is a malfunction with your dryer:
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call.
If you check everything and still have poor heating issues, please let me know. You may have an internal bias or hi-limit thermostat malfunctioning.
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
hi do you have any blockages in the vent system (lint) can you hear the fan running and are the filters clean.did you put it back together correctly.hope this helps.
