Hi guys, I have a 1 year old PS3 which was working fine until I started playing Uncharted 3 used copy. The video and audio was completely out of sync and there were audio cutouts during my first time playing it. So I removed it and played it after a couple of hours after cleaning the disc. Then the problem was sort of fixed and there was no cutouts of sound. So I played it for 3 hours and reached a fire building and the audio came out of sync and there were cutouts. This problem continued for all chapters. But the cutouts and sync issues were not present when I watched the cutscenes manually from the gallery. I think the ps3 is being pushed to its limits during my gameplay. I removed the disc and tried playing Assassins Creed Brotherhood new copy. Unfortunately the same audio cutout had spread to it. The audio which was fine a week ago was now cutting out. This problem was present also in Assassins Creed 2. But the audio was fine when I played GTA IV and Battlefield Bad Company 2. I tried the Full format but it was of no use. I also tried changing my HDMI cable and also using Analog cables. But the problem persists. Please tell me if this is the problem of my PS3 hard-drive or blu-ray drive or software issues or my TV. I am running the new 4.11 software. Should I replace my hdd or something like that... Here is a video link to my problem. You can clearly see that the dialogue sound breaks and returns and sync problems. [url]http://youtu.be/Yn_hw1qd6AI[/url]
Hope your PS3 problem has been solved, and you can play it well, if not, you can have a try to change other consale, and you can get any CD Keys you want if you go to https://www.m8x.com, Games Gold and Games Items are available there, good luck to you
SOURCE: My PS3 will play PS3 games sometimes. It quit
sounds like a dead Laser they are a dual laser will read DVDs n CDs but wont read Blueray movies or PS3 games Laser might need replacing
SOURCE: ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
SOURCE: My PS3 hdmi cable does not work
First off, if you want to use the hdmi remove the supplied composite cable from the back of the ps3.
You don't need both plugged in at the same time, and I'm not sure with the ps3 but some video devices will not enable both at once.
Have your tv selected for whatever hdmi input you have it plugged into. They should be labeled where you plug them in.
With the unit in standby, switch off and red light in front, hold the power button by the disc tray for 3-5 second. You will hear it beep, after the initial turn on beep, then you should see a display set up screen.
If you switch back to the composite, you will have to do this over again.
SOURCE: Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
SOURCE: PS3 audio intermittently cuts out?
you tried switching wires. maybe its your ps3. dont think you can return those can you?
This is a rare problem ............ i faced
similar kind of problem
i solved my problem with the help this repair
guide you can also try this out i hope this will help you a lot .......
all the best
click here to download
