RCA HD52W59 HDTV Projection Television Logo
Posted on Sep 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No signal on dtv do I need a DTV antenna
I just got my new RCA TV Model # L42FHD37YX7 Serial I 166CUOOU
I do have a 120 dollar antenna out doors on a tower 40 ft high.
They run a test the other day, and it said my tv not ready for DTV.
The same day that afternoon they run another test, I hooked a box to the TV, and it worked, but the sound was weak, had turn the vol. way up . need help.
William
richie46
Level 3:
Top Expert:
  • RCA Master 12,962 Answers
  • Posted on Sep 05, 2017
richie46
RCA Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2940970
Points
58151
You have an awesome antenna - every one should have one like it!
An antenna that used to work with the older analog signals will work with the digital ones. What you have to remember is that analog systems though subject to ghosting, were brutes signal wise ala the metal on older cars. Digital signals are frail and even tree leaves in between the antenna and transmitter can have adverse effect on signal received.
If the sound is weak on your set that is a function of your sets audio section. Somewhere you are losing gain and/or amplification. If you have an audio output you might consider hooking that up to one of the audio inputs on audio receiver. It will work fine and that is what I did with my unit.
4 Related Answers
Anonymous
  • 1284 Answers
  • Posted on Feb 12, 2007
SOURCE: Weak Signal ..
Sounds like you have a bad tuner. The most likely cause on these RCA's is a loose RF antenna input connector. A bypass for now is if you have a VCR use it as the tuner and then connect it to the TV using the composite video inputs. If that faisl as well then you have a bad signal board.
Anonymous
  • Posted on Sep 23, 2008
SOURCE: LCD TV LA40A650A1F. TV/DTV
samsung advised  atv/dtv selection by that button not available on australian series 6
ltfrc
Mike Schmidt
  • 227 Answers
  • Posted on Jan 30, 2009
SOURCE: guide plus on my rca p52937 tv
You are right, the Guide Plus is transmitted to your tv over the air. If you have a cable company supplying your programs, your Guide Plus will not receive a signal to set up. You will need to get a two-way splitter. It has two connections on one side and one on the other. The side that has one connection goes to your tv. The side that has two connections will connect to your cable supplier and the other to a rabbit ear or outside antenna. Then the tv has to be off over night to restore your Guide Plus.
prs1c-2266633t98.jpg 2-Way Gold-Plated Bidirectional Splitter pixel.gif Model: 15-2587 | Catalog #: 15-2587 pixel.gif
Use this 2-way gold-plated bidirectional splitter to divide a signal to feed two devices, such as TV...
TONY BIGNELL
  • 147 Answers
  • Posted on Apr 25, 2009
SOURCE: D52W20 RCA
There is a common problem with these with a bad solder connection on the underside of the sweep board. If you can undo all the leads and turn it over you should see it. When you have the board out check for vented capacitors near the front of the board. If you find one change the other caps around it ( four all together ).
1helpful
Mintek DTV-260
The Mintek DTV-260 only has a NTSC (analog) tuner. You will need to connect your RCA antenna to a digital to analog converter box to watch TV over the air. Then connect the output of the converter box to your TV.
The common converter boxes are limited to SD output. You might be able to find an HD converter box online. (With the standard converter box, the available outputs are coaxial and composite video.) The DTV-260 has a composite video port; alternatively set the TV to channel 3 or 4 and use the coaxial (RF) input on the TV.
There may be a low-power station that still broadcasts in analog. However these are rare. You will need to switch from CATV to OTA (Air) to check for one of these stations. Analog Cable has different parameters than scanning for over the air signals.
I hope this helps.
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
4helpful
2answers
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
2helpful
With the hd52w59 do you need a coverter box to hook up a digital antenna??
No this tv have a digital tuner inside.Tv don't require a digital converter box to get a DTV free air signal.Just hook it up with a good digital antena and rescan to find free air DTV,will able to get it.
After the DTV switch, should I be placing the cable cord into the dtv output to receive all the DTV channels? Protron PLTV 3250 is the set I have and it doesn't seem to get the DTV channels like my other...
Your question is confusing. If you have cable, you don't need a DTV converter box.
If your cable company has switched to digital cable, they will provide you a box, and the cable should go from the wall into the box, then into your TV.
If you don't have cable but instead rely on an antenna, then the wire will go from the antenna into the DTV box, then from the DTV box into the back of the TV. If you're using a regular coaxial cable to go from the DTV box into the television, the TV should be set to channel 3. If you're using the red-yellow-white RCA wires between the DTV box and the television, the TV must be tuned to "Aux," "Line In," "Input Select," or whatever it's labeled on your particular set.
1helpful
2answers
Can I receive a digital signal and if so, how?
I'm pretty sure this TV already has an NTSC/ATSC/QAM tuner in there, and should need no converter box whatsover... I say this because I own one...
2helpful
2answers
DTV hookup for an RCA XL-100
Try the $40 RCA DTV Tuner/Converter from Wal-Mart. Connect your existing VHF/UHF antenna (if you don't have one, Wal-Mart sells them too) to the antenna input on the back of the converter and the converter to the antenna input on the back of the TV. If it has only twin lead antenna inputs instead of the standard coaxial type, you'll need a simple twin-lead/coaxial connector, which is about $5. Tune to VHF channel 3 or 4 (set your converter switch correspondingly), turn on the conveter box and follow the onscreen instructions. If you see static, use the automatic or manual fine tune control until you see a clear picture of the menu screen.
Sanyo DS31590 and converter box
I just checked the owners manual online. Looks like this model only has an NTSC analog tuner. No ATSC digital tuner built in.
If you use cable or satellite TV services, the digital converters won't help you. The coupon-eligible ones are strictly for use with a traditional antenna. If this is your situation, ignore the remainder of this message.
If you use a regular TV antenna with this TV, then, yes, you will need a converter box. FYI, the Insignia model at Best Buy and the Zenith at Circuit City, and elsewhere (radio shack) have gotten good reviews from early purchasers. More converter box models will be available in a few months time.
If your current reception with your antenna is poor (snowy), you may have problems receiving the new DTV signals. If not, you should be pleasantly surprised with the quality of the DTV signals - and the extra "virtual" channels. Try the converter box using the RCA video and audio inputs, for a slightly better picture than with the coaxial cable inputs.
Good Luck
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
