what belt did you change? i assume the drive belt. if it is not exactly the right size it wont work. if it is not routed correctly it wont work. it may have slipped off of a pulley.
ed, be sure there is nothing wrapped around the blades. lower the deck and be sure the belt is around all of the pullys. If the belt comes off one of the pulleys or the pulley on the engine it may feel normal but it wont engage the blades.
if the engine didn't shut off as well when you bounced out of seat , you 4 sure have a fault in the seat switch , im under the suspicion that seat switch has two contacts one is 4 engine and one is 4 pto
look underneath did drive belt snap in two , rear has white plastic fan on top of it that should be rotating with engine running if not yep you broke a belt , don't know about wire could it be from front PTO they are electric so it will need a wire ,one possibility is that drive belt broke slapped front PTO and broke off wire , that musta been some snow your pushin ooh and a reminder never push a hydrostatic drive tractor without pump turning it will dammage it
Try it while just coming to a stop.or just starting to move forward. Depress the clutch and push it back towards engagement position....because it's tied to wheel speed the moving parts might allow it to drop in.
