No .. it reads 50 and my humidstat reads 35. Does not say anything in the directions either way.No .. it reads 50 and my humidstat reads 35. Does not say anything in the directions either way.
You can't post conmments that contain an email address.
It isn't necessary you run it 24 hours a day. You can set it to be on for 2 or 4 hour intervals and then it Turns OFF. However, I am a bit concerned that you have the humidity extraction level set a bit high for a basement application. 50% is more than most basements need to be. Lowering it to 35%, will remove more humidity and eventually will run for shorter periods of time. It takes several days of operation for the dehumidifier to get the humidity under control.
If you have a floor drain in your basement, you can use a hose to daring the water, rather than having to empty the bucket daily (which is not that unusual). See your Owner's Manual on how to connect a 48" length of garden hose to the dehumidifier.
I hope this helped you & thanks for choosing FixYa.
Set the temp level at whatever point your home's temperature is now. Lower the humidity level to 35%. If you don't have an LED screen on your unit, set the manual control to maximum.This way, you will extract the maximum amount of humidity and make your home more comfortable.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
The model you have was made by Fedders for Maytag. The fan runs as a recirculating fan, to continually sense when the humidity level rises, above what have the unit set on. Here in, may be the problem. If you have the humidity level set higher than 50%, that's pretty high and the unit want remove much if anything. It will just continue to maintain that level. Keep in mind, the unit's humidity level must be set LOW, for the compressor to kick on and start removing humidity. By low, I mean 35% or minimum, if your unit does not have an LCD display.
I must caution you, that there is associate on this website that would tell you, that the level should be set on Maximum. Believe me, that simply is not the case. That is, unless you want your home to be hot and humid.
Hope this helps you to troubleshoot and solve the problem.
You may have the humidity level set to high. Usually anything above 50%, will show little results, unless your house is flooded.. Turn the humidity setting to the lowest level that your humidifier has and give that a try.
The fan runs a lot, because it's designed to almost constantly move the air around. That way, if the humidity level rises above the setting on the dehumidifier, it can sense it and the compressor will turn ON.
Kreston, check the humidity level you have it set on. It may be that there is not enough humidity in the air for what you have it set on and it automatically shuts OFF.
Keep in mind, whatever level (percentage) you have it set on, is what it will maintain, not remove. For example - if you have it set on 65%, that's pretty high level of moisture/humidity. But, it's not how much it's going to remove from the household air. Unless, the humidity level rises above 65%. Then it will only remove enough to maintain 65%.
If you want to remove humidity/moisture, you have to lower the setting below 45 to 50%, Try that and I think you'll meet with success.
Yes set unit humidity dial about half way or until it comes on. You need something to measure humidity. most of dials dont have a humidity reading. Set at about 50% Rus
As an example, if you want the Humidity % factor to be 50%, 70% or whatever % you want in the space in question to be, set it at whatever % you want the space to be and the humidifier will work until it reaches that setting. It will then shut down until it determines that the humidity has reached a level that requires dehumidifying again. You can set it to run for 2 hours and it then it will shut down for 2 hours, or you can set it to run for 4 hours and then it will shut down for 4 hours. You just have to decide just how humid the area is that you are dealing with.
Go to; www.shopping.com and search for Goldstar Dehumidifiers and you can read comments by others who have purchased this brand. I, myself have one in my celler that has been running for over two years and it has made a world of differance down there.
Good luck. :)
It is showing high because the present humidity is above 80%. Try turning the humidity setting down and let the dehumidifier run for a while. Once the dehumidifier lowers the humidity in the room this level will go lower. If this persists after running for a while you will need to contact LG for service. They back these models with a 5 year warranty. Here is the number to contact them at:
