Heating & Cooling Logo
Posted on Nov 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Amana Gas Fired Air Furnace (80) failed to come on with warm air. Blower works but cold air only? Is there an obvious problem here?
Anonymous
Level 3:
  • Master 1,420 Answers
  • Posted on Nov 19, 2008
Anonymous
Master
Level 3:
Answers
1420
Questions
Helped
849589
Points
3861
If you can look into the viewing port and see if there is a light blinking write down how many times it blinks. Next remove the access panel from the furnace. On the wiring diagram, you will find a diagnostic code chart. Match up the blinking light to the chart and it will give you a starting point.
Anonymous
Level 1:
  • Contributor 34 Answers
  • Posted on Nov 17, 2008
Anonymous
Contributor
Level 1:
Answers
34
Questions
0
Helped
19497
Points
51
First, clean the flame sensor, does the draft motor come on?  could be ignition control board failure
Hi I'm Steve... Amana SSE80 Furnace Model GUIC070CA40 MFG # P1229003F Furnace works but air handler blower stops after 5 1/2 minutes, burner continues till high-T limiter triggered (See details)
Motor might be bad and shutting down on thermal protection. Is this a direct drive or belt driven ? .if belt driven try adjusting the belt tension or just replaced the motor
I have an Amana Air Command 80 SV Natural Gas fired Furnace that is roughly 19 years old.
it should be above the burner on the outside of the heat exchanger square is shape
2answers
Need settings for limit/fan control switch
Possibly it had the 70 on it and someone bumped it up already. I'm uncertain, I'm a straight cool/ minimal heat pump tech in SWFL. I am certain 10 degrees isn't hurting anything, replace with what is in there.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
5helpful
2answers
Amana Air Command 80 SSE gas furnace will not stay running
In the path of the flame on the last burner that starts, there will be a small rod. That rod is the flame sensor. Take a scrub pad and polish it. Also check the electrical connection that goes back to the circuit board. Disconnect any ground wire from the circuit board to furnace cabinet, sand it and replace it.
3helpful
2answers
Amana gas furnace,air command 80 sv. does not ignite blows cold
Hi check out the pressure switch jump it out and see if it lights also check the igntion coil is glowing
1helpful
No power to ac indoor fan motor
sounds like you might have a bad control board. try putting a jumper wire on the control board low voltage terminals R and G your fan should come on and run if you have 120v power to fan motor. double check that you do have 120 leaving board and going to motor. if no 120 bad board if you do have 120 bad motor. if it is the board it likely has a bad blower relay which is common in amana models and goodman equipment.
Amana Gas furnace, Air Command 80 SV. Does not ignite. The blower turns on, then gas valve opens. I can hear a mechanical switch close, which is probably the igniter control. But no spark, no flame. ...
Buy a new ignitor here; The Ignitor Store. Or talk an Amana dealer/Contractor to sell you one. They can range from 15 to 35 bucks! Depending on their mark-up. Give them your model number, and or ignitor part number. Their simple to change out, good luck, please contact if you have any questions.
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
