SOURCE: i m unable to install
If you try to run XP setup without changing the BIOS SATA setting to
ATA mode, setup will BSOD with an 0X0000007B error. Make sure the SATA
setting in the BIOS is ATA...
you will get this error when you will be booting your system from CD and windows installation will be in first step.
to resolve it, go to BIOS setting-->change BIOS SATA setting to ATA mode--->apply changes-->insert windows CD and restart the system-->press f12--->nd boot from CD....hope u will be able to resolve it.
SOURCE: I have an ati display driver error that freezes
Format the PC and then install the latest drivers available from the ATI website
SOURCE: i have Dell inspiron 1525
your HDD may be corrupted, re-installing windows vista is one option. Your best bet is if you have/ can obtain a copy of windows vista run setup and try the repair wizard in the windows vista setup, the wizard automatically finds errors and missing files and replaces them therefore solving any errors in your HDD. you can also try to use the recovery wizard from your recovery disc. best of luck
Testimonial: "thanks for your reply its very helpful"
I have vista and i did system restore(which took 8 hours)
