Watches Logo
A
Anonymous Posted on Apr 19, 2012
I need directions for a MEN'S WATCH N00492/N00493 STEEL- BLUE & SILVER
5 Related Answers
Anonymous
  • 17 Answers
  • Posted on Sep 04, 2008
SOURCE: Skagen watch band issue
You can find generic bands on Ebay or do a Google search for mesh bands. They come in various widths usually in millimeters so you have to measure the width between the lugs where the band connects to the case of the watch. Do a Google search for nomenclature of what a lug is on a watch if you do not know what I mean.
Anonymous
  • 93 Answers
  • Posted on Dec 25, 2009
SOURCE: how to set the time on W12065L1 for Guess Men
you can find a mannual exper cheap wow gold
Anonymous
  • 2501 Answers
  • Posted on Feb 18, 2010
SOURCE: Where can I get a replacement band for this watch
Go to "www.skagen.com/service/home.fx" and you will find contact information.
Anonymous
  • 1970 Answers
  • Posted on Jun 27, 2010
SOURCE: I need user manual/instructions for Slazenger, model not known
mcdevito75 here, You can visit a small watch repair shop in your area for info, as some watch makers only deal with their watches commercialy.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 27, 2011
SOURCE: Armitron Men's 204379BKSV Silver-Tone Stainless-Steel
Usually you would need a watchmakers press for closing the watch back. Without proper tools it is quite difficult, but you can try the following. Take a leather belt and lay it flush on an even, solid surface (stable table will do). Undo the strap (both ends) from watch case by pushing spring bars inwards with pen knife. Lay the watch crystal face down on the leather belt. Belt must be wider than watch itself and the leather must be quite hard and even, not soft. Find the small groove on watch case back and align it very carefully to the watch's winding stem, so, the stem goes directly in the middle in protrusion. Slightly push the case back into the watch case at that groove point and gradually apply pressure with fingers going all way around the case back. Use your body weight if needed. You should hear "click" sound when the case back jumps in to place. If this does not work, there is no other way, but to go and see watchmaker. Hope it will work for you.
1helpful
I haven't worn my fossil watch (FS 4337 model) for some time & decide to wear it & shook it, adjust it, & it dosn't work. Usually when I don't wear it for about 2 weeks, I shake it...
If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
2helpful
I am needing to find out what kind or size battery The Fossil Blue AM-3574 takes and where I can purchase them.
The vast majority of Fossil analog wristwatches take either a #377 or #379 watch battery. The #379, being slightly smaller, is somewhat more commonly found in women's watches than in men's watches, but I have seen both types used in men's and women's watches alike.
These batteries are commonly found at many drug stores, jewelry store counters at places like Walmart and Target, and even at some dollar stores. Be aware that cheap dollar store batteries are usually alkaline, not silver oxide, versions of the same size battery. Alkaline batteries may work perfectly well in many watches, but they have a somewhat different energy performance curve over time, and, in general, they won't last quite as long as a comparable silver oxide battery. In addition, for reasons I've never been able to figure out, some of the Fossil watches that I've serviced would not function with an alkaline battery--but would work fine when I put in a silver oxide battery of the same size and voltage. I have not been able to see a pattern to predict when this will and will not occur.
As a final thought, the backs of some Fossil watches are very snugly fitted to their cases. You can generally get them off without too much of a problem, but there's a good chance you may need a jeweler's press to get them to snap back on properly. I've noticed this most with round watch backs; I generally haven't needed a press to close oblong or tonneau-shaped Fossil watches (or some round watches, too). A jeweler's press spreads the pressure evenly around the edges of the watch back and watch case, preventing damaging pressure on the watch crystal, watch movement, and watch back. Clamping the watch in a regular vise to try to press on the back runs a high risk of damaging your watch, and I do not recommend trying that, no matter how frustrated you get. It's much safer (and cheaper, overall) to tip someone with a vise a couple of dollars to close up your watch for you.
Is there an electronic copy of the operators manual for a Rip Curl Shipstern Tidemaster 2 watch ??
Go to http://www.ripcurl.com/index.php?id=683,4215,0,0,1,0 and select "watch warranty and care".
On the right you will find "
Watch Warranty & Technical Information Booklets Download.
Download the instructions.
How do you shorten the wristwatch?
Thank you for contacting Fixya.<br /> <a href="http://www.webwatches.co.uk/how_to.htm">http://www.webwatches.co.uk/how_to.htm</a><br /> That link will dirct you to directions for different types of bands.<br /> Best regards. Jewel
5helpful
How do I remove watch band links from m Stainless Steel Nautica Watch? Model #A45001G
I've got a great article that helped me out with this same problem! I thought this article explained things pretty well. http://hubpages.com/hub/How-to-Size-a-Watch
Nautica Chronograph Watch for Men-Instruction to set time & Date
hello
i have hour nautica ... number A29506.. i wants to change date ... please tell me how to chenge .. maybe you write in my e-mail
[email protected]
tthenks..
Baume & mercier hampton city watch
Does the dial have "Automatic" wtitten on it". If it does then it's a mechanical movement. If it has "Quartz" then it requires a battery. If the watch isn't running perhaps it just needs a battery. This may also explain why the pushers aren't working. If it's mechanical the watch needs to be wound before the pushers will work. What are the markings on the subdial.
1helpful
Seconds hand does not move,minutes,hour hands ok
Friends:The watch is fine,I did not know how it works,a friend explained this to me.Everything is OK now,thanks for your help.Roberto
Top Nautica Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Nautica Watch Expert? Answer questions, earn points and help others
