I have had the tv about 6 yrs all good , been in the same spot in the lounge room so wife need to change room around , unpluged tv moved it to new spot , plug it in pressed on button nothing is happening stand by red light is blinking & when i go to back of tv & put my ear to it i can hear a ticking sound
My tv is about 6 yrs old and its a prjection tv, when I turn the tv on it cuts on and off 3 times then will not do anything for abot 2 mins then when I turn it on again it does the same thing as before. The picture will not come on unless u do this constantly for 2 hrs strait!!! I can can hear it clicking to come on but it doesnt make it sometimes.
You need to replace the flyback which is flyback 259296 and also capacitor CP150 and CP114. You can get replacement parts at the following link and they include free step by step instructions with pictures so you can easially repair the set yourself. Heres the link. http://servicemanuals.vstore.ca/
Run a coax cable from the sky hd+ box at the rear from the RF2 coax port, and into tv in bedroom. If you want to change channels, buy a magic eye from eBay for a couple pounds, enter sky settings, and turn power on to the RF2 output. this will supply your coax to bedroom with 9v which will power your magic rye
I believe your Lounge TV is an HDTV and your Bedroom TV isn't, This is what you have to do: 1. Connect it to your Lounge TV with an HDMI cable and a red/white/yellow cable. 2. Turn it on and go to the display settings and switch it to the composite cable setting. 3. Change your TV channel where you would see the red/white/yellow cable and accept it that way. 4. You should be all set. Take it to the regular TV and connect it with the red/white/yellow cable. cheers :)
. Make sure that you don't have mute on, and make sure your TV speakers are turn on. Go to menu and see if there is a way to turn your internal speakers on. If you can't fine anything , then your audio processor could be locked up, and if you unplug your TV for 30 MIN. it will reset the processor back to normal. Good luck and have a nice Day.
first check you power box ..remove toe cover.. power box under front... check wire nuts ..make sure power is off... if nut are good you can check heater and door switch...if you have a meter
my question is what is the part number to the whole board that the fly back is on
what is the part number to the whole circut board that the flyback is on
