I'm able to print alignment page and the paper feeds through with no problem. However, when I try to print something up, the paper will not go through the feeder.
Are you getting any error msgs when you try to print? It's possible that you have a communication problem. Make sure that your computer and printer is able to talk.
Since no details were provided, you can try to uninstall the Lexmark software and download an updated driver online at www.lexmark.com.
SOURCE: The black cartbridge is not printing and won't align
Dies this model have a separate print head? Or is the head part of the cartridge? If it is the latter then it seems to be a data transfer problem- which means possibly the contacts in the machine that mate with the contacts on the cartridge are dirty or damaged. In the first instance try gentle rubbing with a moist tissue the in machine contacts then try. Also try the Lexmark website Tech Support Team.
SOURCE: paper feeder won't follow through
I found olasNick's comments very worthwhile. I was also having a paper feed problem and carefully disabled my LEX73 and now clearly understand the comments regarding prying it apart. There are plastic clips that hold all of the plastic together, by gently prying and pushing the clips at the same time I was able to get it apart without breaking any plastic. Once inside the problem was obvious, a broken gear on the roller assembly. I guess I could order a new gear from LEX but at this point, I think I'll take it a sign to retire this old workhorse. I think I got this printer about 10 years ago and can't imagine how many reams of paper have gone through this printer. It doesn't owe me anything.
SOURCE: Lexmark X4650
Here is how to align your print cartridges
Using the printer control panel:
1 Load plain Letter-size paper.
2 From the printer control panel, press tools , and then press ok.
3 Press the arrow buttons until Align Cartridges appears, and then press ok. An alignment page prints.
Using Windows
2 Do one of the following:
• In Windows Vista, click the windows globe (start button) .
• In Windows XP and earlier, click Start.
3 Click All Programs or Programs, and then select the printer program folder from the list.
4 From the printer folder, click Maintenance Align Cartridges.
5 Click Print.
6 Follow the instructions on the computer screen.
Using Macintosh
2 From the Finder desktop, double-click the printer folder.
3 Double-click the printer utility icon.
4 From the Maintenance tab, click Print Alignment Page.
5 Follow the instructions on the computer screen.
If you aligned the cartridges to improve print
SOURCE: alignment problem on lexmark x4650 printer
Try this
Turn off you printer
remove the cartridges
and try gently moving the ink cartridges carrier from left to right
for about a min.
also you can try to wipe machine oil on the bar that holds the ink cartridge carrier
then put the cartridges back inside the carrier
then turn on you printer
and try to print again
If problem persist
TRY THIS:
turn off your printer
unplug the power cable from the printer
lift you printer and put it in an upside down position
then shake the printer from left to right
see if there's any foreign objects stuck inside the printer
An alignment page prints. Once this page prints, your automatic alignment is complete.
This works on Lexmark Printers, if it doesn't let us know what model you have.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
