Iam using an htc dual touch past a year or so.I just changed over from airtel service provider to a vodafone service provider.im facing problems of signal goin every 15 min and then i have to go to the comm manager and switch of my phone and switch it on back and then the signal is back.i first got my sim replaced but im having the same problem i have also hard reseted the phone twice as adviced by an htc official.I really dont know how to solve this problem.this doesnt not have any problem on an airtel service provider.pl help me out
thank you
Niraj sheth
SOURCE: HTC TyTn II data connection problem
It keeps connecting because an application keeps wanting to access the internet.
Make sure you set your email to manually download messages.
Turn the Weather Tab off in HTC Home Screen as it automatically downloads the weather.
Turn off "QuckGPS"
Disable Error Reporting to Microsoft in the System settings
Also remember MMS messages will require internet connection.
Everytime you send a MMS or receive a MMS your phone will connect to the internet.
SOURCE: htc not turn on, red light on
Remove the battery from the mobile, press the power button, for 30 seconds.
Re attach the charger , switch on the phone. If it turns on switch it off again and reinsert the battery and check.
If none of the above steps work, you would have to take it in for repairs as there could be a problem with the power supply inside the phone , that would require special tools to open
Thanks
proton
SOURCE: I'm from india, and having HTC P 3400 mobilile
got to www.vodafone.com and go to india link see for mms and gprs settings there it will help or call ur help line
SOURCE: HTC 3400 gprs setting
first u insert sim and start the machine and wait for open and massage will come automatic seting for this network u sould do yes and wait it will configure automatic seting on device and after setting device will ask restart and done restart that u can use internet surfing on your device if you have GPRS connection from service provider other wise massage will come remote computer has end this programm.
SOURCE: i have problem with vodafone gprs settings on my phone(htc touch)
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
Regards.,
Jay
Hi,are you able to solve this problem?, if so, please let me know how @ [email protected]. thanks a lot..
same problem. please help!
[email protected]
