SOURCE: need to replace the bulb in an epson e71 projector
Hi, this is pretty straight forward. Make sure the projector is off and cooled. On the bottom is the Lamp cover, press the two tabs and lift the cover off. Loosen the two retaining screws and pull the lamp assy upwards to remove. Fit the new lamp and tighten the screws then rfit the lamp cover. You will need to reset the Lamp hours using the "About" menu after turning back on (Not the "reset all" menu).
The user guide can be downloaded from Epson support:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=KBTjt4A8+KgSfbEGuimYvDcGHmpVV+Ko
